front axle u bold
front axle u bold
Postby remi » Thu Apr 19, 2012 9:37 pm
on the front of a dana 60 front what is the part numbers for the front passenger side inner u bolt part
1992 w250, a518, fuel screw borderline runaway, denny t stage 2 fuel pin, cai,4 turbo back straight pipe to 5inch stack, 4 inch lift, 3 and 1 boost, egt, tranny temp,
remi
Re: front axle u bold
Postby BILTIT » Thu Apr 19, 2012 10:02 pm
Inner is not a u-bolt. Stock is studs and most replace with bolts if changing leaf pack height.
Derek B.
BILTIT
Postby remi » Tue Apr 24, 2012 7:55 pm
yeah my front stud snapped so im kinda in a bind
remi
Postby BILTIT » Tue Apr 24, 2012 8:07 pm
Twist it out, EZ-out if needed and put in bolts. Just watch the bolt length and amount of threads to ensure proper engagement without bottoming out.
Derek B.
BILTIT
Postby remi » Wed Apr 25, 2012 7:57 am
yeah its down in there so itll be an adventure for the weekend haha
remi
Postby Mark Nixon » Fri Apr 27, 2012 12:44 pm
Is it broken off down in the hole a ways?
If so, that's actually better.
Take a cheap socket that fits as close as possible to the inside diameter of the hole, then use a punch that fits as snug to the hole in the socket as possible and center punch the broken stud.
A transfer punch that fits the hole in the socket would be ideal. :)
Drill it with a bit @ half the hole's diameter and as straight as possible, then try to use a SQUARE bolt extractor, or the stubby style helix extractor (NOT an E-Z out!) to try to turn it out.
USE HEAT on the casting, if you can do so.
If it wont turn out, then you'll have to basically drill it as thin as possible, then try again, or try to tap new threads.
Postby moab4x4 » Wed May 09, 2012 7:59 am
Mark Nixon wrote:Is it broken off down in the hole a ways?
I agree completely with Mark with the added comment that if you need to drill and tap go ahead and go larger diameter (5/8) and simply drill out your spring plate to match. Studs are a little stronger (cause you can bottom them out and locktite them in good). If you use bolts make sure they go as deep as possible (cut them off or use washers as spacers if you need to). I have abused mine enough that they have been drilled deeper and tapped to 3/4". Grade 8 all-thread from the parts house makes good new studs.
92 W350 LE Getrag, 3.54, 4"/2" lift,
HTT Stage II, POD's, 4", PDR cam, KDP, 3200 GSK, Pin ground, Keyed Valet
Pyro, Boost in Message Center, Isspro tach, Damplifier-ed entire cab! Dual Batts, Keyless Entry, LED's in dash
moab4x4
Postby simplysmn » Sun May 27, 2012 8:01 pm
Or better yet if your good with a welder build up a haystack of weld and then weld a Nut onto it once you get it high enough then you can just put a socket on the Nut and back it out of the hole
simplysmn
Postby remi » Wed May 30, 2012 8:05 pm
got dam simplesnm thats a good i dead im going to do it i weld for a living so im going to give it a shot
remi
Postby simplysmn » Wed Aug 08, 2012 10:49 pm
A buddy showed me that trick on my frontend worked great and we have used that same Idea several times . :D
simplysmn
Postby DodgeFreak » Thu Aug 09, 2012 10:23 am
what the hell does a haystack of weld look like
Postby PToombs » Thu Aug 09, 2012 5:46 pm
A haystack made of weld! :lol:
Postby DodgeFreak » Sun Aug 12, 2012 3:17 pm
is that like a haystack from the old days where they just mound it, or when they would tie it up, or square bale haystack or round bale haystack or big square haystack.......lil confused lol :D :lol:
Postby PToombs » Sun Aug 12, 2012 5:40 pm
Oh, sorry, :oops: an old fashioned mounded one. ;)
And DUH, you can't screw a nut on the square bale shaped haystack, it's square! :lol:
Postby DodgeFreak » Thu Aug 16, 2012 5:02 am
hey he never said anything about screwing on the haystack.....he said to weld a nut on the haystack not screw a nut on the haystack...big difference...... :lol:
