Need some new coils...
Postby Diesel » Wed Jul 18, 2012 8:02 pm
Ok I think its time to replace the front coils. I like rake but the front is so sagged. I don't need the front all high and level with the rear because I load the bed regularly but I would like the front back up to factory height. What coils will give me good ride I have now but a little less saggy. I really don't want the stiff buckboard ride I hear the 7226S springs give. The new springs can be a little taller than stock but ride has to be nice and I still have to be able to load the rear hard without the truck squatting like a nissan frontier/toyota Here is what rockauto.com has available.
1991.5 D250 Intercooled A518
Diesel
Re: Need some new coils...
Postby oldestof11 » Thu Jul 19, 2012 2:13 pm
What I would do is find the spring rate of the 7226S and the load height. Now go down on the numbers slightly to find what you are looking for.
Postby ellis93 » Thu Jul 19, 2012 2:42 pm
I've heard,again "heard" that you can use the poly spacers from daystar for a second gen 2 wheel peel.
If that's true then I'd keep the factory spring and run the spacers,if I liked the current ride and the springs weren't beat.
Postby Diesel » Thu Jul 19, 2012 6:26 pm
Well I'm thinking I might just get some 7226 Moogs but not the 7226S. Maybe even the Rockwell RC7226 (for the price the Rockwells seems amazing but I feel like in a spring you get what you pay for).
Diesel
Postby bmoeller » Sat Jul 21, 2012 11:34 am
I have coil springs on my donor D350, if they might work for ya. Don't know if they are different than what you currently have or not. I don't need them, with having a W350.
SOLD- '99 3500, SO CTD, 5spd
bmoeller
Postby Diesel » Sat Jul 21, 2012 2:54 pm
I'd like to get some new coils under there but I appreciate the offer/idea.
I see spacers on eBay. Any ideas on these?
http://www.ebay.com/itm/71-08-DODGE-2-F ... _593wt_948
Diesel
Postby bmoeller » Sat Jul 21, 2012 3:04 pm
I'd rather have spacers with a closed circle.
bmoeller
Postby Diesel » Sat Jul 21, 2012 3:31 pm
Yeah I am trying to figure out how that spacer works. I am guessing its not closed circle because of the casting on the A-arm.
Diesel
Postby bmoeller » Sat Jul 21, 2012 5:03 pm
I'm not sure. I'll have to take a gander at it. But, if the 2nd gen spacers fit, don't see a reason why these can't be a closed circle.
bmoeller
Postby ellis93 » Sat Jul 21, 2012 5:26 pm
They look to be metal :?: I'd probably try them out 8)
Postby Diesel » Sun Jul 22, 2012 6:38 pm
I'm not really looking for a full 2" of lift in the front because I really don't want it to sit level and then squat hard when its loaded down. I'll try and buy the smallest lift ones I can and report back. I'll need some stock replacement shocks and new isolators too though.
Diesel
Users browsing this forum: No registered users and 74 guests
