Widen Stock Steel Wheels?
Postby o00otii » Fri Sep 21, 2012 8:04 am
Hey everyone. I love the look of the stock wheels and everyone seems to have the alcoa/eagle alloy style wheels. Has anyone ever had a stock wheel split and widened to fit larger tires?
o00otii
Re: Widen Stock Steel Wheels?
Postby BC847 » Fri Sep 21, 2012 8:52 am
Sorta . . :?
Some years ago, I ran some Eaton Steel rims (16.5 x 12). Example: http://www.ntwonline.com/16.5X12-BLACK- ... FyLg66FR0s
They ultimately had to go as I had reoccurring issues with the factory welds coming up with hairline cracks. This happened when the wheels were on the front of the truck. Kept having loss of air in the tires and bubbles found the cracks.
* (If I had to do it again, I would not get the 16.5 rim as the tire bead / rim interface (slips under power) doesn't work as well as the 15" or 16").
Postby chrislib » Fri Sep 21, 2012 10:11 am
Stockton wheel used to do this, they changed ownership so best to ck with them if they still do.
http://www.stocktonwheel.com/index.html
I have a hankering for a set of these
http://www.shopvintagewheels.com/16x10- ... p/WV82004/ but at the time I can`t jutify the expense...I NEED springs and hangers waaay more.
It`s not about how hard ya hit...it`s about how hard ya can GET hit and keep movin forward.
93 W250 CC 4x4, Auto,7x010`s, D-Zilla/16cm, 5in exh, BHAF/Smoky...don`t call it ratty, that`s patina son!
chrislib
Postby Bogie » Mon Sep 24, 2012 12:51 am
Yes Stockton still offers this service along with Weldcraft I can attest to Stockton as I had them build a set of 15x10 small bolt Mopar steelies for my dart about 20 years ago.
1984 Dodge W350 Crew Cab 9"Lift 37" SSR's 360/NP435 D60's W4.10's
1966 Dart 273HP 4Speed 3.90's Radio/Heat Delete
Bogie
Users browsing this forum: No registered users and 76 guests
