Fred_M1010 wrote:I might have expressed myself poorly, I only meant that it's hard to follow the recommended procedure when tightening the nut, not that it needed a certain preload.
I wouldn't be surprised if the recommended procedure even gives you more than zero lash...
RCCUMMINS89 wrote:David has rear brakes? I want some too.
RCCUMMINS89 wrote:well originally yes, I forgot to put discs..... but then I decided not to change it because, how many of us actually have rear brakes that work like they are supposed to ALL the time.
