rear wheel nut removal...plz help!!!
Postby Rusnak12 » Tue Apr 02, 2013 3:04 pm
cant find anything to remove my rear wheel nut to remove the drum on my 92 d350 drw. anyone know the size or a part # for a socket or tool to remove this nut so I can service my rear brakes? have a factory special tool # but was wondering if anyone knew any tips for this sorta thing without buying the factory tool...that is if they still make it/have one around?
Rusnak12
Re: rear wheel nut removal...plz help!!!
Postby PToombs » Tue Apr 02, 2013 3:58 pm
It's a 2 -9/16 socket. Any NAPA or autoparts store should have one, and they aren't that expensive. I have done it with a chisel by wedging it in edgeways and turning the drum, but the socket is lots easier! ;)
Postby bmoeller » Tue Apr 02, 2013 4:50 pm
Not a regular 2 9/16" socket either. Needs to have the more rounded corners on it. The OTC socket was something like $40-50.
SOLD- '99 3500, SO CTD, 5spd
bmoeller
Postby BC847 » Tue Apr 02, 2013 7:13 pm
Before I eventually got the right socket, I'd simply take a large, flat blade screwdriver and wedge it in between the hub interior, and the leading edge of one of the flats on the nut. Then spin the rotor with a large wrench.
Works good. :)
Postby PToombs » Wed Apr 03, 2013 4:05 pm
Yup, that's what I used to do BC! ;)
Postby Fred_M1010 » Wed Apr 03, 2013 11:31 pm
Me too, when I removed it.
But it's hard to get the proper pre-load for the wheel bearings when you re-assemble it,
so I would strongly suggest getting the correct tool for it.
But I couldn't find the correct tool over here, so I used the nuts from a Chevy front dana60 when I re-assembeled mine, cause I already had built a special socket for that earlier.
So that works as well, the threads are the same.
-91.5 W250
Fred_M1010
Postby ellis93 » Thu Apr 04, 2013 4:05 am
You all can say what you want but...I have NEVER preloaded ANY full floating axles bearings,I've always got them to zero lash and called them good. I've never had any come back on me either. ;)
Postby Fred_M1010 » Thu Apr 04, 2013 4:31 am
I might have expressed myself poorly, I only meant that it's hard to follow the recommended procedure when tightening the nut, not that it needed a certain preload.
I wouldn't be surprised if the recommended procedure even gives you more than zero lash... :?:
-91.5 W250
Fred_M1010
Postby ellis93 » Thu Apr 04, 2013 4:57 am
Fred_M1010 wrote:I might have expressed myself poorly, I only meant that it's hard to follow the recommended procedure when tightening the nut, not that it needed a certain preload.
That was a general statement,ive often seen people preload them and I guess it works out for them but I'm not one that will tempt fate by putting more stress on old surfaces. :lol:
Postby RumbleFish » Thu Apr 04, 2013 6:17 am
I just follow the tq spec in the fsm. Good enough?
Postby RCCUMMINS89 » Thu Apr 04, 2013 8:10 am
David has rear brakes? I want some too.
Postby dazedandconfused » Thu Apr 04, 2013 9:50 am
RCCUMMINS89 wrote:David has rear brakes? I want some too.
I'm guessing there is a word missing here? ;)
Postby RCCUMMINS89 » Thu Apr 04, 2013 10:05 am
well originally yes, I forgot to put discs..... but then I decided not to change it because, how many of us actually have rear brakes that work like they are supposed to ALL the time.
Postby ellis93 » Thu Apr 04, 2013 11:42 am
RCCUMMINS89 wrote:well originally yes, I forgot to put discs..... but then I decided not to change it because, how many of us actually have rear brakes that work like they are supposed to ALL the time.
Me :mrgreen:
Postby RCCUMMINS89 » Thu Apr 04, 2013 11:57 am
Are they the original drums?
