by Remps » Thu Jun 27, 2013 8:24 pm
Then you might as well get the bigger bolt in IC radiator, thermostat housing to go with it, and then the fan will have about 1/4" room to the bigger rad, so might as well get a shallower IC fan...
unless you are just doing it for the IC look, you'd just have to fab some rad mounts.
