intercooled front clip on non i/c pickup?
Postby 406CTD » Fri Jun 07, 2013 9:36 pm
Hey guys just bout a 1990 w250 auto here in Portland Oregon. Seen a intercooled front clip without the intercooler for sail on Craigslist for 40 bucks. Just wondering if the are a direct swap to older trucks? Or is it worth it to just fab a cooler mount?
406CTD
smoke screw?
Re: intercooled front clip on non i/c pickup?
Postby PToombs » Sat Jun 08, 2013 3:47 pm
Does it have the core support? That is the only difference between IC and non-IC front ends, the IC support has the cut outs for the tubes.
Postby GO OVRIT » Sun Jun 09, 2013 10:09 am
The headlights are higher on the 91-93 trucks. The gassers and early 91's use the intercooled grill, but the core support is still different. The vertical support pieces are different and the mounts for the cooler are not there. If you get everything from an intercooled truck, its easy. (Core support, grill , radiator, water outlet, a/c condenser, valence) If you're not getting this stuff, expect some fab work.
GO OVRIT
Postby PToombs » Sun Jun 09, 2013 4:51 pm
I didn't realize the headlights are higher! I knew about the radiator and thermostat housing, but he was asking about the front clip so I didn't go there.
Postby RumbleFish » Sun Jun 09, 2013 4:59 pm
yep, and I believe they also stick out further to match the thicker grille.
Postby Remps » Thu Jun 27, 2013 8:24 pm
Then you might as well get the bigger bolt in IC radiator, thermostat housing to go with it, and then the fan will have about 1/4" room to the bigger rad, so might as well get a shallower IC fan... :lol: unless you are just doing it for the IC look, you'd just have to fab some rad mounts.
Postby CumminsPower59 » Thu Jun 27, 2013 9:43 pm
I wonder if there is a slight difference between fenders too, as I have two different fenders on my 91, and the older one seemed to pull the core support back about 3/8", causing misalignment...
Postby Remps » Mon Jul 01, 2013 2:14 pm
If I had to guess I'd say sloppy production tolerances. I put the nice dash out of my 86 parts truck in my D250, about half the screw holes lined up. Managed to force most of them in. :roll:
Postby CumminsPower59 » Mon Jul 01, 2013 3:40 pm
I think you're right. I pulled both fenders off a truck recently, both in decent shape....might have to swap them on...
Postby Remps » Mon Jul 01, 2013 10:42 pm
I was thinking it might also depend where the truck was manufactured. I've got a mexican, american, and canadian first gens. :lol: Maybe the molds or dies (or however they made fenders) were slightly different between plants.
Postby cougar » Wed Jul 03, 2013 10:19 am
Why not use a 2nd gen intercooler?
01 2500 "the work truck".
cougar
Postby Mark Nixon » Wed Jul 03, 2013 11:53 am
There's a cascade effect to doing all this. :lol:
If you swap to the I/C front clip you end up needing the following INTERCOOLED parts:
Radiator.
Fan Shroud.
Fan hub with pulley.
Fan blade.
T-stat housing.
Longer fan belt.
Why the longer belt, you ask?
In my experience the I/Ced fan hub combined with the non-intercooled A/C compressor and mounts ends up with things being further apart.
It's a ~1" difference.
In addition to this, the A/C condensor needs re-mounted (fabricated).
Cause and effect at it's finest.
It's not HARD to do, if you have the parts and you know the differences, but it'll make you think you're going nuts if you don't.
