swapping bodies
swapping bodies
Postby Renigade » Sat Aug 17, 2013 10:02 pm
can I take the body off a 1998 1500 gassier and put it on a 1993 d250 frame it is diesel powered
1993 1st gen BHAF -Smoke screw 2.5 turns, star wheel 2.5 turns. Fuel screw 1.25 turns, fuel pin ground.
Renigade
Re: swapping bodies
Postby Kasper Cummins » Sun Aug 18, 2013 4:49 am
You can but it won't bolt right up. Swapping drivetrain might be easier.
92 W250 club cab
Kasper Cummins
Re: swapping bodies
Postby Renigade » Sun Aug 18, 2013 7:23 am
will the front suspension fit the half ton frame. I know the rear will work but the front has me guessing
Renigade
Re: swapping bodies
Postby dazedandconfused » Sun Aug 18, 2013 8:02 am
No the 1st and 2nd gen suspension is different. Depending on what you are using the truck for you can use the half ton drive train.
Re: swapping bodies
Postby Renigade » Sun Aug 18, 2013 12:42 pm
pulling my camper and daily driver
Renigade
Re: swapping bodies
Postby Renigade » Mon Aug 19, 2013 7:54 am
will the half ton body be strong enough to handle what I want to do. I know it does with the gasser but brakes the bank on fuel useage' the body on my 93 is eat up with rust and I need the cab space on the 98 to do what I need to do.
Renigade
Re: swapping bodies
Postby dazedandconfused » Mon Aug 19, 2013 10:39 am
The body is no stronger from 1/2 ton to 3/4 ton. You can always go to a junk yard and pick up the 3/4 ton front suspension. I'm not sure on the frame difference though between the two. I'd personally swap the ending and everything over and beef up what's needed. Are these 2wd or 4wd trucks?
Re: swapping bodies
Postby Renigade » Mon Aug 19, 2013 1:44 pm
they are both 2 wheel drive the 98 I have had for several years and it is in excellent shape. if the swap is feasible then I would love it to be that way. I don't mind doing without the 3/4 ton frame if the half ton will hold the motor okay
Renigade
Re: swapping bodies
Postby dazedandconfused » Mon Aug 19, 2013 2:20 pm
The newer half ton frames are much stronger then mine and I haven't had a issue. Many guys are running half ton conversions now. Is your camper really heavy or could you pull it with the half ton now?
Re: swapping bodies
Postby Renigade » Mon Aug 19, 2013 3:39 pm
I have pulled it many times with my half ton with no problems
weighs 66oo with all the stuff we put in it.
Renigade
Re: swapping bodies
Postby dazedandconfused » Mon Aug 19, 2013 5:35 pm
I'd swap in you motor and upgrade to a 47rh or 5 speed for towing. If you can pull it with the half ton no need to swap suspension in my opinion.
Re: swapping bodies
Postby Renigade » Mon Aug 19, 2013 8:39 pm
thanks for the advice I have a getrag that has been gone through behind that 5.9 now so that should work out well
Renigade
