steering box trouble
Postby T.winegar » Sat Jul 12, 2008 9:54 am
i have a 91 dodge that is not very responsive to the steering wheel. when i'm driving straight down the road, i can turn it to the right a 1/2 turn with no reaction from the truck. it is loose i think. how do i fix this? can i just tighten my steering box, or do i have to buy a new one?
89 727-stageIvcomp 4in intake-amsoil air filter, 4in exhaust, dennyT, 366 spring. pump turned up to make me smile! low stall converter, rebuilt tranny at 120,000miles
T.winegar
It's the coupler....
Postby Ace » Wed Jul 16, 2008 9:40 am
You probably need to either rebuild/replace the steering coupler or get a new Borgeson steering shaft. Borgeson is the best option - u-joint will last alot longer than that crappy slip socket Dodge used.
It's the joint attached right behind the steering box. Just reach in there, grab ahold of it with one hand and try turning the shaft with the other hand to see for yourself.
Ace
