PToombs wrote:Check the rear spring/shackle area.
stock91w350 wrote:do u guys mean the rear of the front shackels? i check and the rubber stop that points down is really close...
what am i lookin for? lol. also i noticed the springs are bent down like a frown instead of up like a smile. lol normal?Ace wrote:stock91w350 wrote:do u guys mean the rear of the front shackels? i check and the rubber stop that points down is really close...
Yep, may be time for new springs. Look on the frame right behind the shackle where the spring eye bolt goes through...
it has the rubbers and there close to touching just sitting there, it doesent have to be a big bump and i dont have to be going fast either for it to happen. it just started doing this in the last couple weeksRichie O wrote:Jack it up and if the wheels don't fall off, she is good.The springs do bend backwards. You also might be pounding the bump stop rubbers or they rubbers may be broke off. I think my other truck I had was missing a rubber stop and it would pound bad on a bump. Its an old truck it has a right to make some sounds.
