something loose?
something loose?
Postby stock91w350 » Sat Jan 30, 2010 5:16 pm
every time i hit a sharp bump it feels like something slaps up underneith my left foot, i looked under there and there is nothing there exept the cab mount but it looks all good, any ideas? also when my hubs are locked in and in both 2 or 4wd it makes a chatter noise from the passenger side, maybe the u joint?
91 w350 5spd dually. 5"stack, fuelpin, starwheel all in, smoke screw all in, homemade cold air intake
stock91w350
Postby Tacoclaw » Sat Jan 30, 2010 7:39 pm
On my truck, both the brake calipers and the little clamp-things that keep the leaf springs from spreading too far made a clanging noise when I hit bumps in my truck.
I just put some some silicone caulking on the clamp and hammered some folded-up steel in the caliper gaps.
Postby U.S MMA » Sat Jan 30, 2010 9:48 pm
jack it up and give a shake down.
90w250,5spd,flatbed,dually swap, power lock ,kelderman, fresh trans rebuild, valair stocker,newer 9leaf,2"skyjacker
3200,60wheel65 16 pacbrake,60exhaustsprings,93 head, snowstage3,
custom bumper broken winch,topboxes,underboxes. J&H helped out a lot. slowly restoring(real slowly)
U.S MMA
Postby PToombs » Sun Jan 31, 2010 8:27 am
Check the rear spring/shackle area. Are the springs bottomed out? It could be the spring eye hitting the frame when you hit a bump.
Postby Ace » Sun Jan 31, 2010 9:10 am
PToombs wrote:Check the rear spring/shackle area.
That would be my vote. Perfectly fits the description.
Postby stock91w350 » Sun Jan 31, 2010 12:44 pm
do u guys mean the rear of the front shackels? i check and the rubber stop that points down is really close to touching, is that normal? i have about 1000lbs of sand in the back but its pushed back to the tailgate and doesent go past the whee lwells, I would figure that would make the front higher? all i have on the front is plow gear, the plows not on it
stock91w350
Postby Ace » Sun Jan 31, 2010 5:14 pm
stock91w350 wrote:do u guys mean the rear of the front shackels? i check and the rubber stop that points down is really close...
Yep, may be time for new springs. Look on the frame right behind the shackle where the spring eye bolt goes through...
Postby stock91w350 » Sun Jan 31, 2010 5:26 pm
what am i lookin for? lol. also i noticed the springs are bent down like a frown instead of up like a smile. lol normal?
stock91w350
Postby Richie O » Sun Jan 31, 2010 5:34 pm
Jack it up and if the wheels don't fall off, she is good. :D The springs do bend backwards. You also might be pounding the bump stop rubbers or they rubbers may be broke off. I think my other truck I had was missing a rubber stop and it would pound bad on a bump. Its an old truck it has a right to make some sounds.
Postby stock91w350 » Sun Jan 31, 2010 5:44 pm
Richie O wrote:Jack it up and if the wheels don't fall off, she is good. :D The springs do bend backwards. You also might be pounding the bump stop rubbers or they rubbers may be broke off. I think my other truck I had was missing a rubber stop and it would pound bad on a bump. Its an old truck it has a right to make some sounds.
it has the rubbers and there close to touching just sitting there, it doesent have to be a big bump and i dont have to be going fast either for it to happen. it just started doing this in the last couple weeks
stock91w350
rattle
Postby jbaker » Mon Feb 01, 2010 5:39 am
mine has a rattle and slap under my left foot also mine is the old steering shaft sloppy in the joint
93' w350 extended cab drw getrag, pump turned up and twisted, skirted flatbed
93 w350 extended cab drw auto, flatbed
jbaker
Postby hounddogks76 » Mon Feb 01, 2010 8:21 am
Check the bushings in the shock mounts, could be one missing.
Nothin' better than diesel!!!!!!!! 91 W350 SRW
hounddogks76
Postby 84t0y » Tue Feb 02, 2010 4:07 pm
honestly ive never been inside the front axle on these trucks but on toyotas thats a common description of loose or worn wheel bearings.
newbie checkin things out.
84t0y
Postby Ace » Tue Feb 02, 2010 7:25 pm
Those bearings would have to be waaaaay loose to get clear up under your foot! :lol:
