leaf spring hanger
leaf spring hanger
Postby dazedandconfused » Thu Feb 03, 2011 8:49 am
Where can a guy get a rear driver side spring hanger for a 93 D350 cab and chasis? I need the hanger that mounts to the frame.
Re: leaf spring hanger
Postby cougar » Sat Feb 05, 2011 9:05 am
I tried the yards but what they had was just as bad as what needed replacing. Wound up buying 1 ton shackles and had to re-bush the leaf spring and drill up the hole in the frame.
01 2500 "the work truck".
cougar
Postby dazedandconfused » Fri Feb 11, 2011 2:58 pm
Nobody has one on a parts truck? Really need one to put my cab and chasis rear back under it.
Postby Richie O » Fri Feb 11, 2011 4:55 pm
Just keep looking and asking. I found a set from the west coast. Dodge still has them, but they are not cheap.
Postby dazedandconfused » Fri Feb 11, 2011 5:23 pm
What's the difference in the 250 and 350 hangers? I know were a 250 frame is.
Postby Richie O » Fri Feb 11, 2011 5:33 pm
I know my 93 w250 has the bigger spring eye bolts. What I ended up doing was finding a set that had the smaller holes and bought a big drill bit to get to the correct size. My 89 has the smaller spring eye bolt. I am pretty sure any mount from a gasser or diesel truck will work, as long as you can match the spring eye size.
Postby dazedandconfused » Fri Feb 11, 2011 5:41 pm
That's what I was thinking. Have to check it out.
Postby dazedandconfused » Fri Feb 11, 2011 6:29 pm
Well I found new ones finally. They range from $94-$125 depending on bolt size. Have to check my old one.
Postby cougar » Sat Feb 12, 2011 10:30 am
dazedandconfused wrote:Well I found new ones finally. They range from $94-$125 depending on bolt size. Have to check my old one.
Were did you get them? When I needed them Dodge had discontinued them and there were non available. I had to use the 1 tons, rebush my leafs and drill up the frame.
cougar
Postby dazedandconfused » Sat Feb 12, 2011 10:47 am
Postby Richie O » Sat Feb 12, 2011 11:24 am
Those are pretty good prices. It comes with the bolts and some kits even have the spring eye bolt. I have alot of money just in all the bolts to put it back together. Sure beats dodge prices.
Postby dazedandconfused » Sat Feb 12, 2011 11:31 am
They were the first place that came up when I googled it.
Postby cougar » Sat Feb 12, 2011 2:32 pm
Oh well, if I want to put 1 ton springs in i'm half way there.
cougar
Postby Richie O » Sat Feb 12, 2011 3:34 pm
One thing is I have not seen a cab and chassis hanger, so I am not sure if they are the same as a pick up hanger.
Postby dazedandconfused » Sat Feb 12, 2011 3:35 pm
I believe they are all the same. That looks like my messed up one.
