rear drum star wheel question
Postby rusty93 » Wed Feb 23, 2011 9:55 pm
Hey guys, i have a rear passenger wheel locked up due to below freezing temps (i think) and was wondering if turning the starwheel migh help release the pressure. which way do i need to turn the starwheel to do this. thank you in advance
rusty93
Re: rear drum star wheel question
Postby Richie O » Wed Feb 23, 2011 10:04 pm
Is the ebrake cable stuck? If its just the shoes rusted to the drum try beating it with a hammer. Just be somewhat careful. A guy here in town put his truck in low range and busted the backing plate mounts right off the axle housing by trying to drive it. :lol: He is also the guy who got his chimney brush caught in the chimney and tore it right off the house hooked to his pickup. :lol: :lol:
Postby Richie O » Wed Feb 23, 2011 10:06 pm
As far as starwheel question, you can try to losen, but drums usually don't get overtight unless its adjusted that way manually. Not sure on direction. I always have to figure that out. :roll:
Postby Tacoclaw » Thu Feb 24, 2011 3:27 pm
I *think* the star wheels are directional, and if they're not, something in there is. Just turn them in the direction with the most resistance.
Postby aje1127 » Thu Feb 24, 2011 4:12 pm
you will need to move the star wheel upward,to back them away from the drum.
to do this you need a screwdriver in the hole to hold the small arm that touches the star wheel,hold it towads the backing plate,while turning the star wheel upward with brake adjuster or another screw driver. good luck
aje1127
