madabi81@aol.com wrote:is there a separate flasher for the hazard lights? because they work just fine but no turn signals...... where is the flasher located
burnt_servo wrote:madabi81@aol.com wrote:is there a separate flasher for the hazard lights? because they work just fine but no turn signals...... where is the flasher located
i want to say there are 2 flashers ...... it should be located on the inside of the dash panel , directly under your steering colum .
PToombs wrote:Huntinguy, have you checked the bulbs? A bad one will cause that. Start simple! If that doesn't work, start checking the wires for a bad connection or break.
huntinguy wrote:PToombs wrote:Huntinguy, have you checked the bulbs? A bad one will cause that. Start simple! If that doesn't work, start checking the wires for a bad connection or break.
Thanks I'll try that.
