No Turn Signals!
No Turn Signals!
Postby Kebo » Sat Feb 20, 2010 9:51 pm
I tried searching, but I believe the search function is not working properly. Last week I was driving my pickup and realized that the turn signals were not working. I tried pounding on the dash to get them to work, they didn't. I then giggled the lever and they started to work momentarily, but they quickly stopped. Any ideas? I haven't looked into this at all, so I don't know if it could even be the fuses.
'93 W250 LE Standard cab w/ getrag swap. 210k slightly tweaked pump
Kebo
Re: No Turn Signals!
Postby PToombs » Sun Feb 21, 2010 3:02 pm
If it worked when you wiggled the lever it's not a fuse. May be the signal unit itself in the column. I saw one once that the contact rivets had melted into the plastic and wouldn't make contact.
Postby Kebo » Sun Feb 21, 2010 10:09 pm
Yeah, I've been driving it a little bit more and I can get the signals to work about 30-40% of the time, so it's not a fuse. I guess I'll have to start taking apart the column. :roll:
Kebo
Postby madabi81@aol.com » Mon Feb 22, 2010 2:28 pm
any luck on this yet? I happen to have the same problem and now they are not working at all ......... uhoh :roll:
madabi81@aol.com
Postby burnt_servo » Mon Feb 22, 2010 5:46 pm
i'm with pete on this ,
but you should check the flasher unit first , they can get sticky with age , and wiggling the signal lever can sometimes send enough of a " pulse " of voltage to get the relay to work for a few moments again .
'93 w250 .... stock ...
burnt_servo
Postby PToombs » Mon Feb 22, 2010 7:08 pm
Another good idea! I haven't had a flasher go bad in quite a while, but it happens.
Postby madabi81@aol.com » Tue Feb 23, 2010 7:35 am
is there a separate flasher for the hazard lights? because they work just fine but no turn signals...... where is the flasher located
madabi81@aol.com
Postby burnt_servo » Tue Feb 23, 2010 10:40 am
madabi81@aol.com wrote:is there a separate flasher for the hazard lights? because they work just fine but no turn signals...... where is the flasher located
i want to say there are 2 flashers ...... it should be located on the inside of the dash panel , directly under your steering colum .
burnt_servo
Postby Kebo » Wed Feb 24, 2010 10:48 am
I haven't touched this issue yet. Been too busy to work on this thing, so I've been drivin the beater around. It gets better MPG's anyways. I'll see what I can do this weekend.
Kebo
Postby huntinguy » Mon Mar 01, 2010 2:28 pm
I'm interested in this too. The blinkers on my truck only work on the right side, the left don't work at all.
89 non-I/C W-250, flatbed. 4" turbo back. Ground fuel pin, AFC tuning.
huntinguy
Postby PToombs » Mon Mar 01, 2010 6:22 pm
Huntinguy, have you checked the bulbs? A bad one will cause that. Start simple! If that doesn't work, start checking the wires for a bad connection or break.
Postby DieselSharker » Wed Mar 10, 2010 9:24 am
Yep, there are 2. One of mine decided to pop out a few weeks back and I couldn't figure out what it was since it got kicked under my seat. There are flashers on either side of the fusebox. One for the hazards, one for the directionals.
1991 W250 727, 6" Skyjacker, 37" Dick Cepeks, Gear Vendor O/D, SDX 5x.014s, BHAF, home-made 4" intake, VE tuning & DennyT II pin, GDS 60mm with 16 cm, CoolerTubz 3" crossover
SUPPORT YOUR VETERANS!
DieselSharker
Postby huntinguy » Wed Mar 10, 2010 8:42 pm
PToombs wrote:Huntinguy, have you checked the bulbs? A bad one will cause that. Start simple! If that doesn't work, start checking the wires for a bad connection or break.
Thanks I'll try that.
huntinguy
Postby madabi81@aol.com » Wed Mar 24, 2010 6:17 am
This fixed mine, flasher was actually good which is what was throwing me off. It was actually wiggling itself loose in the housing.
madabi81@aol.com
Return to Electrical
