will this tach work?
Postby blacksmoking » Sun Oct 30, 2011 5:58 am
1993 d350 g360 Cummins, 5x20's non ic pump, Afro engineered fuel system. 2wd puller, Sled dragger.
blacksmoking
Re: will this tach work?
Postby Hansen01 » Sun Oct 30, 2011 7:05 am
i have this in my truck if you wanna spend a little extra cash, easy to install easy to read and easy to set
http://www.ebay.com/itm/AUTOMETER-SILVER-2-5-8-MINI-DIESEL-TACHOMETER-TACH-/260345855122?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item3c9dd27c92
Under construction...
Hansen01
Postby Richie O » Sun Oct 30, 2011 8:07 am
Hansen01 wrote:i have this in my truck if you wanna spend a little extra cash, easy to install easy to read and easy to set
You have what? the one like in the sale add? I know some people have issues with a regular tach reading the low 5 volt signal the factory tach wire sends.
Postby dazedandconfused » Sun Oct 30, 2011 9:33 am
I haven't been able to get the gas tach that was in my truck before to work with the factory wiring harness.
Postby oldestof11 » Sun Oct 30, 2011 9:42 am
Andy, do you know where it picked up the signal?
Postby dazedandconfused » Sun Oct 30, 2011 10:06 am
It was originally wired straight to the coil to start with on the 318 and worked then. It's a Equus Products Pro racing tach.
Postby blacksmoking » Sun Oct 30, 2011 11:18 am
well thanks for the responses, i think i will just wait it out and buy an autometer or isspro.
blacksmoking
Postby Hansen01 » Sun Oct 30, 2011 6:55 pm
srry guys, must not have been with it this morning, :roll: i edited my post with the URL :D
it reads off the alternator, i didnt use any of the factory tach wire stuff(if i even have them) jus spliced into wires
Hansen01
Postby ellis93 » Sun Oct 30, 2011 7:16 pm
dazedandconfused wrote:It was originally wired straight to the coil to start with on the 318 and worked then. It's a Equus Products Pro racing tach.
MSD makes a signal converter that let's analog tachs use the signal from distributorless ignition systems on newer cars and trucks. It uses the crank sensors like our trucks have.
Postby dazedandconfused » Sun Oct 30, 2011 7:19 pm
I think I'll just go to an Isspro. The one I've got is old and doesn't look that great.
Postby ellis93 » Sun Oct 30, 2011 7:26 pm
It would probably be more accurate too ;) I've used a lot of the equus stuff and found it lacking,don't get me wrong you can't beat them for the money but when it needs to read right I use something better.
Postby Gots_a_sol » Sun Oct 30, 2011 7:28 pm
dakota digital makes a converter box as well. That is what I use to run my tach. I added a W wire to my alternator for the signal to the converter.
-Joe
Gots_a_sol
Postby dazedandconfused » Sun Oct 30, 2011 7:34 pm
ellis93 wrote:It would probably be more accurate too ;) I've used a lot of the equus stuff and found it lacking,don't get me wrong you can't beat them for the money but when it needs to read right I use something better.
Yeah that's what I figured after looking them up. Would like all my gauges to be similar when I'm done. It's also a big tach and be hard finding a place out of the way to put it.
Postby ellis93 » Sun Oct 30, 2011 7:45 pm
I have had my autometer diesel tach for almost 6yrs with no problems. It does however read off the alt and if you buy one you'll have to move it around the alternator case to find the most accurate signal. Least that's what I had to do :lol:
Postby Hansen01 » Mon Oct 31, 2011 5:31 am
ellis93 wrote:I have had my autometer diesel tach for almost 6yrs with no problems. It does however read off the alt and if you buy one you'll have to move it around the alternator case to find the most accurate signal. Least that's what I had to do :lol:
maybe we jus got lucky then lol we jus strapped it on and it was right at 900 and 1500rpms, (revs up and hard to keep a steady rpm after that) :D
Hansen01
