Hansen01 wrote:i have this in my truck if you wanna spend a little extra cash, easy to install easy to read and easy to set
dazedandconfused wrote:It was originally wired straight to the coil to start with on the 318 and worked then. It's a Equus Products Pro racing tach.
ellis93 wrote:It would probably be more accurate tooI've used a lot of the equus stuff and found it lacking,don't get me wrong you can't beat them for the money but when it needs to read right I use something better.
ellis93 wrote:I have had my autometer diesel tach for almost 6yrs with no problems. It does however read off the alt and if you buy one you'll have to move it around the alternator case to find the most accurate signal. Least that's what I had to do
