IowaCummins wrote:so basicaly start throwing parts at it and see if it fixes it? well i guess im off to the dealer to order the cps. does anyone know the part number for it?
Philip wrote:Yes we do have a check engine light. Cycle the key on/off/on/off/on. Then count the flashes on the check engine light. Watch closely. There is a short pause between flashes when it is changing number. All codes will be a two degit number.
Philip wrote:If you not going to do the key test to see what the codes are. Your next best option is to find a shop with a scanner and have them hook it up. It would be cheaper than throwing parts at it till you get lucky.
