i didnt know we had a check engine light?!
Postby IowaCummins » Sun Jul 19, 2009 10:43 am
ok comming home from work this morning ym check engine light came on that i didnt even know this truck had? lol so can i read codes on this truck or what? what could be wrong? just about anything i supose?
IowaCummins
Postby Philip » Sun Jul 19, 2009 1:13 pm
Yes we do have a check engine light. Cycle the key on/off/on/off/on. Then count the flashes on the check engine light. Watch closely. There is a short pause between flashes when it is changing number. All codes will be a two degit number.
Postby dpuckett » Sun Jul 19, 2009 3:10 pm
Most likely the alternator /voltage regulator. That is the only thing I've ever had the Check Engine light come on for in 3 different trucks.
Daniel
Postby IowaCummins » Wed Jul 22, 2009 5:48 am
so i havent done the key thing but im pretty sure its the alternato/ regulator story. casue the truck hasnt been charging for two days now and it pretty self explanitory. but when you guys get this code what do you replace? alternator or regulator or what? thanks guys
IowaCummins
Postby IowaCummins » Thu Jul 23, 2009 10:51 am
has this happened to anybody else? what needs to be replaced? thnaks
IowaCummins
Postby IowaCummins » Fri Jul 24, 2009 9:33 pm
well i took the crank positioning sensor and set it a .050 gap like its suposed to be and still its not charging and a check engine light is on. so what is it a bad CPS? how much do they run from the dealer?
IowaCummins
Postby SNOOT » Fri Jul 24, 2009 10:30 pm
Mine was the CPS what sucks is I replaced alt, PCM before the CPS. Expensive week.
1993 W350
SNOOT
Postby Richie O » Sat Jul 25, 2009 7:39 am
I had a bad CPS also.
Postby Philip » Sat Jul 25, 2009 10:29 am
If you not going to do the key test to see what the codes are. Your next best option is to find a shop with a scanner and have them hook it up. It would be cheaper than throwing parts at it till you get lucky.
Postby IowaCummins » Sat Jul 25, 2009 11:09 am
ok well i think its the cps. i had the alt checked on engine and it said the engine never started so i figured it just the cps. monday i will have to get one. its a dealer only item right?
IowaCummins
Postby IowaCummins » Wed Jul 29, 2009 12:23 pm
is there any way of seeign if th e cps is functioning or not? i had a on vehicle alt test and they said it never sensed the engine starting. thats what leads me up to it but the dealer wants $115 for a new cps and i would rather know before i buy it. thanks guys
IowaCummins
Postby Richie O » Wed Jul 29, 2009 1:26 pm
There is a way but you have to have a set up to send a 8 volt signal and then read the return signal. You also have to know which wire does what. I have none of the above. You may also have a bad ASD relay, PCM or wiring trouble. Those would also cause those problems.
Postby IowaCummins » Wed Jul 29, 2009 2:38 pm
so basicaly start throwing parts at it and see if it fixes it? well i guess im off to the dealer to order the cps. does anyone know the part number for it?
IowaCummins
Postby Richie O » Wed Jul 29, 2009 2:41 pm
IowaCummins wrote:so basicaly start throwing parts at it and see if it fixes it? well i guess im off to the dealer to order the cps. does anyone know the part number for it?
Philip has some good info.
Philip wrote:Yes we do have a check engine light. Cycle the key on/off/on/off/on. Then count the flashes on the check engine light. Watch closely. There is a short pause between flashes when it is changing number. All codes will be a two degit number.
Philip wrote:If you not going to do the key test to see what the codes are. Your next best option is to find a shop with a scanner and have them hook it up. It would be cheaper than throwing parts at it till you get lucky.
Postby IowaCummins » Wed Jul 29, 2009 4:10 pm
ok i went out and did teh key thing. it goes liek this.
111 - 111- 111- 1111- 11111-1111
so 3 - 3 -3 - 4 - 5 - 4.
so is the code 33 34 54?
thank you guys
IowaCummins
Return to Electrical
