winshield wipers gone nuts
Postby manyholes » Fri Jul 08, 2011 12:53 pm
hey guys, was running the truck in the mountains in BC and it started to overcharge, tried to make it to the next town, spiked to 18+volts, trailer brake in the truck started smoking, shut the truck down , fried a pile of electrical, trailer brake, pump soleniod, all lights . had to pull the fuse on the wiper motors because they are stuck on. changed out the voltage regulator, batttery, cleaned the engine and body ground, fuel soleniod, truck is running good now less wipers. any input would be apreciated thanks
1990 W250 dodge ex cab, LB, work in progress. truck was originally reg cab/lb, ex cab is an add on.fuel pin turned, 30psi, bhaf, straight piped 3", new rear springs with shackle flip, 4" lift front, crossover steering, waiting on piston lp, c/c s/b conversion, turbo upgrade and intercooler install
manyholes
Re: winshield wipers gone nuts
Postby Hansen01 » Fri Jul 08, 2011 4:16 pm
:D mine did that a couple times, but never burned up any wires, man do those wipers really go :shock:
Under construction...
Hansen01
Postby manyholes » Fri Jul 08, 2011 4:54 pm
so is it the switch or?? havnt opened up the motor but i know on my old chev there was a microboard that would fry
thanks
manyholes
Postby manyholes » Fri Jul 08, 2011 10:01 pm
well the rain let up so i dug around a bit, intermitent wiper relay is fried behind the ashtray. wipers now work, just all or nothing, partstore tomorrow lol. at least it beats having to pull a fuse the last couple of days
manyholes
Postby Hansen01 » Fri Jul 08, 2011 10:56 pm
haha good thing you figured out what it was, cus never fried it, although when i turn them on sometimes the swipe more times than they should, could that also be that modual?
Hansen01
Postby manyholes » Sat Jul 09, 2011 7:58 am
wouldnt be able to tell ya, someone with more 1st gen electrical knowledge might chime in on this tho
manyholes
