Where to buy a crank position sensor?
Postby Mt. Tam trucker » Sat Oct 01, 2011 2:15 pm
Hello,
This is my first post on this forum.
I have a 93 w250, auto, 280,000 mi. I have owned it for 8 years, it had 140,000 mi. when I got it.
I need to replace my crank position sensor. I can order one from the dealer for $140. Does anyone know where I might buy one for less?
Also, I read on here that the gap is supposed to be .050", this info does not appear in my 93 Factory Dodge Truck Service Manual, am I just not finding it in the manual. There is a some info on the sensor on 8D2, 8D8, 8D18l, or is there another manual that I should buy?
Thanks,
Chris
Mt. Tam trucker
Re: Where to buy a crank position sensor?
Postby Mt. Tam trucker » Sat Oct 01, 2011 3:13 pm
I have found a couple more sources, my dodge dealer said the part # is 4746691 Genos Garage lists one that they say is for CUMMINS 3924432 SPEED/CRANK POSITION SENSOR ('94-'97)
Is this the same sensor? http://www.genosgarage.com/prodinfo.asp?number=3924432
The mounting bracket looks different, does it matter?
Thanks,
Chris
Mt. Tam trucker
Postby ellis93 » Sat Oct 01, 2011 5:58 pm
You can't find one at your local parts house? If you have the dodge part number they should be able to cross it
Postby dpuckett » Tue Oct 18, 2011 6:40 pm
For ANY engine part, go to Cummins. Mom got a crank position sensor for her jalopy for around $50 or so a few months back.
Postby slow_90firebird » Sat Oct 22, 2011 8:09 pm
I have a 93 w250 and when mine went bad I got one for a 1994 at autozone it was cheap. The only difference is the mounting bracket but it still bolted up fine. It uses the same electrical plug and I set the gap using the cardboard off a book of matches.
slow_90firebird
