ABS Sensor on rear axle....different use????
Postby idaho1990 » Thu Nov 24, 2011 10:49 am
I was wondering if the rear abs sensor is a hall effect sensor. Anyone know? I have swapped a 47rh and a 241DHD transfercase so I no longer have a VSS for a speedometer. If the rear ABS sensor is a hall effect I can utilize it as the sender for an autometer programmable speedo. I would like a speedo that reads a little higher than the stock one and can reprogram it for tire changes/ratio changes since this is my drag truck. I drive it on the street from time to time so I need to know how fast I'm going. Thanks in advance....
1990 W250 drag truck. Benched 215 pump, s364 over s595, Contagious Diesel 5x0.020's with some work, Contagious Diesel Comp DV's, Dual fed, tork tek, Fire Ringed, hamilton springs, ARP 2000s, airdog 150, 3 piece manifold, Nitrous by NX, 47rh, np271, 3.07's, caltracs, rolling on Nitto 420 305/50r20s looking to break into the low 10s this spring
idaho1990
Re: ABS Sensor on rear axle....different use????
Postby ellis93 » Thu Nov 24, 2011 3:10 pm
Yes it will work. Some have used it along with a signal converter to work with the factory head in 6speed conversions, but I've no idea about the autometer.
Postby idaho1990 » Thu Nov 24, 2011 10:17 pm
Thanks, all I need to do is figure pulses in a 2 mile distance and i'm good. Not too bad just math, but its turkey day and it can wait until tomorrow.
idaho1990
