by hemislave » Thu Mar 08, 2012 6:42 pm
A couple of days ago turned the wipers on, for a nano second they started to work then quit. checked the fuse looks ok. swapped in a new fuse just in case.Nothing, cant hear or feel the motor running. Got my test lite out and checked for power at the motor, the plug for the motor has 4 lugs, has power at the 2 left terminals. I asume this is normal? I then ran a jumper wire of the battery to test the motor and got no response there. I guess the motor is toast ? Any ideas
85 crew cab 1st gen ve pump tweaked a lil. 4:10s auoto o/d gauges boost,pyro. 16cm exhaust housing .285/75/16 nitto terra grapplers,rebuilt a518 w/a decent torque converter.
