wipers quit working
wipers quit working
Postby hemislave » Thu Mar 08, 2012 6:42 pm
A couple of days ago turned the wipers on, for a nano second they started to work then quit. checked the fuse looks ok. swapped in a new fuse just in case.Nothing, cant hear or feel the motor running. Got my test lite out and checked for power at the motor, the plug for the motor has 4 lugs, has power at the 2 left terminals. I asume this is normal? I then ran a jumper wire of the battery to test the motor and got no response there. I guess the motor is toast ? Any ideas
85 crew cab 1st gen ve pump tweaked a lil. 4:10s auoto o/d gauges boost,pyro. 16cm exhaust housing .285/75/16 nitto terra grapplers,rebuilt a518 w/a decent torque converter.
hemislave
Re: wipers quit working
Postby Tacoclaw » Thu Mar 08, 2012 7:04 pm
Usually it's the little plastic clips that connect the motor to the linkage. It's only a few screws to pop off the cowl panel and check it out.
Postby hemislave » Thu Mar 08, 2012 7:22 pm
Tacoclaw wrote:Usually it's the little plastic clips that connect the motor to the linkage. It's only a few screws to pop off the cowl panel and check it out.
Yeah, I will check those out as well, I didnt think it was that because I can turn the wipers by hand theres a lot of resistance, I can fell the motor turning. Thanks
hemislave
Postby ellis93 » Thu Mar 08, 2012 9:02 pm
that motors brushes could just be stuck. Turn the wipers on and bump the motor with a hammer. Should jar the brushes so they'll touch the armature again.
Return to Electrical
