NEED HELP with wiring brake controller
Postby 93DodgeCummins » Sat Apr 17, 2010 11:37 am
I have 93 dodge cummins. Im trying to wire up the wiring that goes to the tail light system. Where is the place to wire it in?
93 Dodge W250 4X4, Custom air intake, Diamond Eye 4 inch turbo back straight pipe exhaust, HX-35W with Banks upgrades, KDP fixed, Getrag 5 speed, Isspro Tach, pyro, fuel pressure, and boost. Raptor 150, 3200 rpm spring, Power Screw in 1 turn, aftermarket fuel pin
93DodgeCummins
Re: NEED HELP with wiring brake controller
Postby Philip » Sun Apr 18, 2010 7:19 pm
Our trucks didn't come with the brake controller wiring installed. You need to run a wire back to the rear for that.
Postby 93DodgeCummins » Sun Apr 18, 2010 9:39 pm
yep i wired it in by cutting the white wire that comes out of the switch the engages when you step on the brake. Then i sodered in a wire and sodered it all back together. I got everything working. So im good to go.
93DodgeCummins
