NEED HELP with wiring brake controller
Postby 93DodgeCummins » Sat Apr 17, 2010 11:37 am
I have 93 dodge cummins. Im trying to wire up the wiring that goes to the tail light system. Where is the place to wire it in?
93DodgeCummins
Re: NEED HELP with wiring brake controller
Postby Philip » Sun Apr 18, 2010 7:19 pm
Our trucks didn't come with the brake controller wiring installed. You need to run a wire back to the rear for that.
Postby 93DodgeCummins » Sun Apr 18, 2010 9:39 pm
yep i wired it in by cutting the white wire that comes out of the switch the engages when you step on the brake. Then i sodered in a wire and sodered it all back together. I got everything working. So im good to go.
93DodgeCummins
Return to Electrical
