TPS Problem
TPS Problem
Postby firstgenjunkie » Wed Feb 23, 2011 9:28 am
My TPS has been giving me problems for a while so I replaced it with a pot. No problems and it worked great until two days ago....now no matter what I do the truck will not shift into OD. Ideas for trouble shooting? I'm on the east coast and my books are back in Texas so any ideas would be greatly appreciated.
Would the fusible link on the driver's side cause this problem? All my electrics are working as the should.
1992 Dodge D350 Dually. EV2 Pyro & Boost, BHAF, Denny T Stage 2 pin, 366 spring, 4 inch exhaust and mildly tweaked pump. 2nd gen split bench, full replacement bumper/grill, and mobile comm suite.
firstgenjunkie
Re: TPS Problem
Postby ellis93 » Wed Feb 23, 2011 11:03 am
I'd get a test light and check for fire at the plug on the trans, with key on. If it does you could jump a ground to the other wire and use a toggle switch. If no fire then fuse checkin time.
Re: TPS Problem
Postby firstgenjunkie » Wed Feb 23, 2011 2:53 pm
Where is the plug on the tranny, near the VSS?
firstgenjunkie
Re: TPS Problem
Postby ellis93 » Wed Feb 23, 2011 4:58 pm
Driver side near shift lever on trans
Re: TPS Problem
Postby firstgenjunkie » Wed Feb 23, 2011 11:32 pm
Cool. I will check it out later this morning.
firstgenjunkie
Re: TPS Problem
Postby firstgenjunkie » Thu Feb 24, 2011 7:21 pm
So I'm officially a knucklehead. i went to change the oil and saw that the OD was disconnected. :oops:
Anyhow, thanks for the help Ellis. My POT is doing it's job again and everything is as it should be.
firstgenjunkie
Re: TPS Problem
Postby PToombs » Fri Feb 25, 2011 6:40 pm
Be Thankful, that was an easy fix! 8)
Re: TPS Problem
Postby firstgenjunkie » Sun Feb 27, 2011 6:33 am
I am very thankful Pete. Normally when something acts up, I'm beating my head against the firewall in frustration.....or inspiration depending on who you talk to. :)
firstgenjunkie
Re: TPS Problem
Postby Mark Nixon » Sun Feb 27, 2011 9:08 am
firstgenjunkie wrote:I am very thankful Pete. Normally when something acts up, I'm beating my head against the firewall in frustration.....or inspiration depending on who you talk to. :)
Well, either way, frustration or inspriration, do it hard enough and long enough and you will "see the light". :lol:
Not to mention having to do body work to the firewall. :?
