neutral safety switch
Postby ciamcoop » Mon Mar 07, 2011 4:29 pm
So I swapped out my auto for a getrag and I tried to start it but it won't crank. I think it's probably the neutral switch since I didn't wire it together. Maybe? .... I gave the connectors away with the auto so now I don't know what wires are for the neutral switch. Anyone know which wires they are? Thanks
'93 W250LE 4x4 club cab, getrag, denny t, 366 spring, 181/210 cam, bored. 020, KDP, 5x.014's, piston pump, 4" tbe, cold air, 255/85/16s, 3.54's one wheeler peeler
ciamcoop
Re: neutral safety switch
Postby lvrider » Tue Apr 26, 2011 6:09 pm
I have an auto swapped to a getrag as well. I bought it this way and on the home from driving it I wondered what happen if i moved the shifter. Nothing happened when driving, but the possibly the next time I tried to start the truck it wouldn't start. I say possibly because I do not recall if I messed with the shifter before or after the no start. Yes I have tried simply shifting the truck back into park and neutral. So I might be in the same boat as you. I ordered a service manual off amazon for 50 bucks. When I get the book I will try finding the wire if no one else gets back to you first.
1990 IC'd, POD injectors, 35 BFG MTs, 4inch straight pipe, 6" lift. BHAF mod...
lvrider
Postby cumminz90 » Fri Jun 03, 2011 8:36 pm
Just swapped the getrag in a 93 and and if your laying under the truck at the auto wiring harness look for a round plug with 3 wires going into it. What I did was cut the plug completely off, run the middle wire to a ground and that basically disables the neutral safety switch and the truck will start in gear. The remaining to wires go to the reverse lights and you run them right to the 2 prong switch on the shift tower of the getrag. DO that an your truck should start with the key. Hope that helps.
1990 D250 sc Cummins: 175 p pumped motor: (400ccs)100 plate, 4k springs, rack plug,Jl machine 5x16 injectors, ad150, cooler tubz, hellman sump, studs, valvesprings, hx35/3b twins, timing 20 *, soon to be built 47rh
GFs: 1993 w250 cc: Normal pump mods, timing to the head, 3200 spring, denny t stage 2, DDP 4 injectors, hx 40, swapped in a rag
1991 w250 rclb: normals pump stuff 3200 spring
cumminz90
