rear bench?
rear bench?
Postby manyholes » Mon Sep 05, 2011 2:43 pm
anyone change out their jump seats for a rear bench? im thinking it'd be tight but might work, my '90 has a bench but its aftermarket extracab that i think is a few inches longer than my '92 ex cab. wifes complaining bout having the kids in jump seats. i like 'em but that doesnt mean i can change her mind :roll: :roll:
thanks guys
1990 W250 dodge ex cab, LB, work in progress. truck was originally reg cab/lb, ex cab is an add on.fuel pin turned, 30psi, bhaf, straight piped 3", new rear springs with shackle flip, 4" lift front, crossover steering, waiting on piston lp, c/c s/b conversion, turbo upgrade and intercooler install
manyholes
Re: rear bench?
Postby dazedandconfused » Mon Sep 05, 2011 5:11 pm
I saw on the web a few years ago where a guy put a Ford ext. Cab seat out of a mid 90's in the back of his and it looked good. Not sure how much room he had though.
Re: rear bench?
Postby manyholes » Mon Sep 05, 2011 8:43 pm
when i make it to the wreckers when im home ill take some measurements. was just trying to see if it was done and i would know ahead of time what bench to pull, its just to fit the kids so it doesnt have to be too roomy, thats what my 90 crewcab project is for
manyholes
Re: rear bench?
Postby CumminsPower59 » Wed Sep 14, 2011 8:13 pm
I went to a wrecking yard last friday, I was scouting out rear seats for the same reason. I found that the rear seats from a 97 on up furd f150 measure in nicely. They are two separate pieces, but if you are crafty with a mig welder and some 1/8" steel, you could make the appropriate brackets. The seat part (where your hind end goes) is about 16" deep and the width is 60". Forgot the height of the back. But I do remember, it's not too tall to fit unfder the recessed portion under the rear window. The mounting feet would have to be cut down a few inches as it's quite tall, and ford has the back section attached to the back of the cab. One could make the hooks/loops/whatever you call them, to attach the back to the back of the cab, or build brackets and attach it to the seat or the floor...
Re: rear bench?
Postby manyholes » Fri Sep 23, 2011 8:19 am
thanks cp59 when i get back to civilation ill check it out, im stuck in red earth creek right now
manyholes
Users browsing this forum: No registered users and 68 guests
