Summit Cab Visor
Summit Cab Visor
Postby slingshot » Mon Aug 03, 2009 9:20 am
Does anyone have , or know someone who has, a Summit cab visor on their truck? I just got some pictures from Summit, of the visor, and it looks ok, but i would like to see one on the truck.
I wanted the Lund visor, but Summit no longer sells the Lund visor. My family all got me gift certificates at Summit to get a Lund visor, but by the time I got them, they no longer have them. So I might get the Summit brand visor, if I could see one it would sure help me out. Thanks
1993 W250 5speed.
slingshot
Postby Farmboy » Mon Aug 03, 2009 10:08 am
Here is my truck I am not sure what brand it is but here it is anyway. I will tell you that the air flow sucks with this thing. While going down the road if you try to spray your windshield with washer fluid it sprays forward insead of on the windshield because of the bad air flow. The air just makes a big loop on your hood :roll:
Farmboy
Postby slingshot » Mon Aug 03, 2009 10:26 am
Good looking old truck.
That looks to be a Lund visor.
1993 W250 5speed.
slingshot
Postby IowaCummins » Mon Aug 03, 2009 12:20 pm
that must be your bug deflector doing all that stuff with the washer fluid. cause my truck has no problems at all with thw fuid and i have the same visor as you. only thing i do not like about it is when its parked the rain or dew drops from the visor on the windshield and if you do rainx it takes that stuff off three times as fast. usually the whole window will still bead water 3-4 weeks after the application and in the spots where it drips its maybe 1-2 weeks.
IowaCummins
Postby slingshot » Mon Aug 03, 2009 4:20 pm
Here are the pictures that Summit sent me of their visor.
1993 W250 5speed.
slingshot
Postby PToombs » Mon Aug 03, 2009 5:47 pm
If you put a visor on make sure you check the screws once or twice a year, they get loose from the vibration. I had a Lund on my 91 S10. I loved it.
Postby RumbleFish » Mon Aug 03, 2009 6:49 pm
while ill agree visors look nice, the mpg's they detract dont. to each their own.
Postby slingshot » Mon Aug 03, 2009 7:17 pm
Its not a Prius! lol
1993 W250 5speed.
slingshot
Postby IowaCummins » Mon Aug 03, 2009 10:22 pm
this is what mine looks like it is the lund tho. Image
IowaCummins
Postby redneckroot » Tue Aug 04, 2009 7:38 pm
Where are you located? I have one if your interested
redneckroot
Postby slingshot » Sat Aug 08, 2009 8:36 am
Well, after all of that, I decided to order the one from Summit, but when I went to place the order, they dont sell one for an extended cab, only regular cab. That was alot of time and research wasted.
1993 W250 5speed.
slingshot
Postby Richie O » Sat Aug 08, 2009 5:07 pm
I would bet money that that part of the roof is EXACTLY the same as a reg cab.
Postby slingshot » Sat Aug 08, 2009 7:18 pm
Well, I have looked at the two, and the roofs are different, the regular cab roof is taller at the drip rail.
1993 W250 5speed.
slingshot
Postby Richie O » Sat Aug 08, 2009 7:30 pm
I will have to compare my 89 to the 93. I had never noticed a difference but then again I had no reason to look. :oops:
Postby RumbleFish » Sun Aug 09, 2009 7:27 am
no richie, they are different. in 81, the reg cabs got a squared off from edge. the crews and x-cabs used the same rounded front edge as they 72-80 trucks.
