by comotionman » Sat Mar 19, 2011 7:39 pm
they will likely be hub centric so you need to see what the hub id is on the wheels. what did they come off of? gm uses 4.56" hubs, dodge is 4.77" and ford is 4.88" if i remember correctly. you may be looking at opening up the hole on the wheels or getting some hub centric rings made. you will also need to make sure the 5/8 studs fit through the holes and locate some swivel washer lugnuts. i looked into this and kinda did all the homework. alcoa dealers are little or no help if you tell them you have a first gen dodge they will claim alcoa does not make a dually wheel that fits. bs. if you need some hub rings made i found where to go and have the info in my notes somewhere...
coupla trucks non & ic, 2nd gens, various other
