19.5's
both inside and out
19.5's
Postby truckwrench1 » Mon Mar 14, 2011 6:26 pm
ok guys looking at a set of take off alcoas ( 19.5's ) and was wandering if any 1 runs them and if there is any fitment issues thanks in advance for your time truck is a 93 2wd dually
truckwrench1
Re: 19.5's
Postby comotionman » Sat Mar 19, 2011 7:39 pm
they will likely be hub centric so you need to see what the hub id is on the wheels. what did they come off of? gm uses 4.56" hubs, dodge is 4.77" and ford is 4.88" if i remember correctly. you may be looking at opening up the hole on the wheels or getting some hub centric rings made. you will also need to make sure the 5/8 studs fit through the holes and locate some swivel washer lugnuts. i looked into this and kinda did all the homework. alcoa dealers are little or no help if you tell them you have a first gen dodge they will claim alcoa does not make a dually wheel that fits. bs. if you need some hub rings made i found where to go and have the info in my notes somewhere...
coupla trucks non & ic, 2nd gens, various other
comotionman
Re: 19.5's
Postby truckwrench1 » Sun Mar 20, 2011 6:55 pm
man much thanks for tour reply you are the first in 4 differnt forums to make a reply if it is not to muck to ask could you look thru your notes on the centering ring thanks in advance for you time :D
truckwrench1
Re: 19.5's
Postby comotionman » Sat Mar 26, 2011 8:21 pm
contact junior at motorsport-tech.com he can set you up with some hub centric rings.
comotionman
Return to Body
