LE trim package
LE trim package
Postby captmatthew1 » Sat Jan 22, 2011 4:20 pm
how can you tell for sure your truck is le trim without looking at the badges. i think mine might be an le but it had been painted and whatnot before i got it and think that the p.o. may have removed the le badges.
i got a build sheet from dodge that said slt, but from my understanding slt was not available until the 2nd gen trucks. i also went to autocheck.com and ran the vin and it listed there as a 92 ram 250 custom/le.
i would like to confirm my suspicions on this and know for sure. what options came on the le? how are some other ways you can tell a le from a regular truck?
1992 W250 5 speed, pump maxxed, 366 spring, caravan seats, white gauges, more to come.
captmatthew1
Re: LE trim package
Postby Tintacker » Tue Jan 25, 2011 10:30 pm
I would say the big difference is the interior options. My 92 LE has power locks, mirrors, windows, cruise control, tilt wheel, a/c and lots of fragile plastic trim.
I thinks the LE's had some chrome accents too like chrome trim on the tail lights?
SOLD: :( '92 W250 LE auto PDR 190's, 3200 spring, Skyjacker 2" front springs with Bilstein 5100s
'01 2500 QC/SB 4X4 6sp, camper puller
Tintacker
Re: LE trim package
Postby captmatthew1 » Thu Jan 27, 2011 2:44 pm
Tintacker wrote:I would say the big difference is the interior options. My 92 LE has power locks, mirrors, windows, cruise control, tilt wheel, a/c and lots of fragile plastic trim.
thats why i think mine is a LE. i have power windows, locks, mirrors, cruise, tilt, a/c, i have chrome around my tail lights, the pretty tailgate trim, and the front bumper has all the black accents with the bumperettes.
the only thing i am missing is the LE emblems to confirm it. when i run the vin under autocheck it says custom/LE so i assume it is, but that doesnt confirm it for me. can i call a dealer? will they be able to tell me?
captmatthew1
Re: LE trim package
Postby Tintacker » Thu Jan 27, 2011 3:33 pm
Pretty sure you have an LE.
I have never done this but supposedly you can give a dealer the vin and they can print you out a copy of the build sheet. This might be for the newer trucks though?
Worth a call to the dealer I guess.
Good luck. Let us know if they can give you a printout.
Tintacker
Re: LE trim package
Postby captmatthew1 » Thu Jan 27, 2011 5:45 pm
i previously got a build sheet, but from my research, they have reused some of the older codes for newer options. the build sheet says SLT Decor Group, which i am guessing replaced the LE Decor Group when they removed LE from the available options. here is a copy of my build sheet:
Dear Matthew:
Thank you for contacting the Chrysler Customer Assistance Center.
We are pleased to provide vehicle build information for your 1992 Dodge
Power Ram W250.
According to our records, your vehicle was equipped from the factory
with the following:
*F1
-S8
ADAP Light Group
AHLS Heavy Duty Insulation Group
AJKP Convenience Group
AJPP Power Convenience Group
APCA Center Band Two Tone Paint
ASPP SLT Decor Group
BANS 120 Amp Alternator
BCLS 1075 Amp Maintenance Free Battery
BGJS Pwr Disc/Drum Rr Anti-Lock Brakes
BKHS 12x2.5 Rear Drum Brakes
CBAS Straight Back Bench Seat
CDES Hinged Back Seat
CHES Deluxe Headliner
CKEP Front Seat Area Carpet
CURP Rear Compartment Storage Tray
DBBC All Manual Transmissions
DDD 5-Speed HD Manual Transmission
DHES Man Shift-on-the-Fly Transfer Case
DJFA Dana M60/248MM Front Axle
DMDS 3.55 Rear Axle Ratio
DRES Dana M70/267MM Rear Axle
DSA Anti-Spin Differential Rear Axle
ETB 5.9L I6 Cummins Turbo Diesel Engine
GACS Tinted Glass Windows
GBBS Tinted Windshield Glass
GCBS Front Door Tinted Glass
GFDP Rear Sliding Window
GNAS Rear View Day/Night Mirror
GPPP Power 6 x 9 Bright Mirrors
GVBC All Vehicles W/Power Mirrors
HAAP Air Conditioning
HGAP Hood Insulation
JBBP Instrument Panel Woodgrain Bezel
JCDS 100 MPH Primary Speedometer
JHAP Var Intermittent Windshield Wipers
JJAS Cigar Lighter
JJBP Dual Note Electric Horns
JKAS Locking Glove Box
JPAP Power Windows
JPBP Power Locks
K17P STRIPE/BADGE/MOLDING
K27P STRIPE/BADGE/MOLDING
LAAP Ignition Time Delay Lamp
LAFS Key in Ign/Seat Belt Warning Buzzer
LAJS Headlamps On Warning Chimes
LBAP Map/Courtesy Lamp
LBCP Glove Box Lamp
LBDP Ash Tray Lamp
LDAP Underhood Lamp
LMAP Halogen Headlamps
LPEP Cargo Lamp
MBFP Bright Rear Bumper
MFDS Bright Grille
MHAS Black Windshield Moldings
MPBP Black Tailgate Applique
MWDP Removable Tailgate w/Caliper Latches
NBLS Delete EVAP Control System
NEMS Exterior Sound Control
NFES 24 Gallon Fuel Tank
NHKS Engine Block Heater
NHMP Speed Control
NMCS Heavy Duty Engine Cooling
NZAS Diesel Emissions
PACA Silver Star Metallic Clear Coat
QS7A Dark Silver Metallic Clear Coat
RAAC All Radio Equipped Vehicles
RASP AM/FM Cassette Radio
RCDP 4 Speakers
SBAS Power Rack and Pinion Steering
SCEP 2-Spoke Soft Feel Steering Wheel
SFBS Front Heavy Duty Shock Absorbers
SGBS Rear Heavy Duty Shock Absorbers
SUAP Tilt Steering Column
TBBP Full Size Spare Tire
TBMP Tire Carrier Winch
TZHP Michelin Brand Tires
WDAS 16X6.0 8-Stud Wheels
WLBP Steel Spare Wheel
WLYC All Steel Wheels
WMAS Black Hub Caps
WMCP Bright Wheel Trim Rings
XBSA Pickup Box
XEFS Transfer Case Skid Plate Shield
YAAS Build To U.S. Mkt. Specifications
YCG Satellite Radio Edit Waiver
Z6BS GVW/Payload Rating
1AAS U.S. Dealer Retail
4AXA Assembly Plant Tracking
4M1P Retail to Bid Diversion Tracking
6CN Paint Order Code
captmatthew1
Re: LE trim package
Postby Richie O » Thu Jan 27, 2011 8:48 pm
It won't have the 24 gallon fuel tank. All the furnace fueled trucks had the 30.
Re: LE trim package
Postby Tintacker » Thu Jan 27, 2011 8:56 pm
Richie O wrote:It won't have the 24 gallon fuel tank. All the furnace fueled trucks had the 30.
Yep, probably won't have the Power Rack and Pinion Steering and satellite radio either. :shock:
I guess they did reuse some of the old codes.
Tintacker
Re: LE trim package
Postby captmatthew1 » Fri Jan 28, 2011 2:57 am
i dont know, when its on empty with the fuel light on, i can only squeeze about 20-22 gallons in it. u sure its 30 gallon?
captmatthew1
Re: LE trim package
Postby Richie O » Fri Jan 28, 2011 2:10 pm
As I understand it the diesel truck came standard with the 30 gallon tank. Thats how its spelled out in the factory service manual. That being said, who knows what dodge did. :lol:
Re: LE trim package
Postby Tacoclaw » Fri Jan 28, 2011 3:59 pm
My truck will only hold about 22 gallons on a completely empty refill as well. It had the 30 gallon tank on the build sheet, but there's no way it would be able to hold it.
Re: LE trim package
Postby PToombs » Fri Jan 28, 2011 6:44 pm
Pull the sender module, reach in and cut the inside part of the vent, a plastic tube. Mine stuck almost 3 inches down in the tank, now I can cram pack it full.
That being said, I've run my tank really low and only gotten 28 in it.
Re: LE trim package
Postby captmatthew1 » Sat Jan 29, 2011 3:34 am
PToombs wrote:Pull the sender module, reach in and cut the inside part of the vent, a plastic tube. Mine stuck almost 3 inches down in the tank, now I can cram pack it full.
great info, thanks for the tip. wonder why dodge let that one slip? :lol:
captmatthew1
Re: LE trim package
Postby PToombs » Sat Jan 29, 2011 6:55 pm
Emissions or what ever. It leaves a larger air gap for when the fuel expands it won't run over on the ground.
