trans tunnel?
trans tunnel?
Postby dazedandconfused » Sun Feb 20, 2011 3:47 pm
Is there a difference in the tunnel between an auto and a standard? This would be on my 93 Ext. Cab. They are at the farm and I haven't been out there to look for myself.
Re: trans tunnel?
Postby PToombs » Sun Feb 20, 2011 6:13 pm
Yup. Auto 2wd is a narrow one. Auto 4x4, standard 2wd, or standard 4x4 are the wide ones.
Re: trans tunnel?
Postby dazedandconfused » Sun Feb 20, 2011 6:22 pm
Ok kinda what I thought.
Re: trans tunnel?
Postby oldestof11 » Sun Feb 20, 2011 8:37 pm
Pete, you sure?
My 93 Ext Cab auto had the wide one... Room enough for the 4x4 shifter. Straight on the drivers side, 3 angle bow on the passanger side.
Re: trans tunnel?
Postby Richie O » Sun Feb 20, 2011 8:42 pm
Somewhere after 90 or 91 they gave up on different tunnels. They all went with the big ones in 92 and 3. Mark will correct me if I am wrong.
Re: trans tunnel?
Postby dazedandconfused » Sun Feb 20, 2011 8:53 pm
I hope it's the big tunnel keeps me from having to cut it up.
Re: trans tunnel?
Postby PToombs » Mon Feb 21, 2011 7:17 pm
Jon, now that you mention it, I do remember somebody said all ex-cabs were the wide tunnel.
That's why I'm not afraid to stick my neck out and give info, I know somebody will cut it off if I'm wrong! :mrgreen:
