ellis93 wrote:,didn't really notice a difference in the truck other than a little lowend smoke.....I'm talking a little puffthat truck was such a turd on takeoff it had me pushing and pulling on the steering wheel....
Did you slide the AFC housing forward as well as the plate? If the AFC housing is back too far, you can actually LOSE power, even if the plate is slid full forward, and/or ground.
Don't waste the money on delivery valves, unless pulling out a set of 131s. Then, I'd only get the 181s. The 191s just mainly add a lot of smoke and higher EGTs, and no power.
A 97 Ram auto p-pump is 14* timing stock. Put mine to 16.25*. Dropped EGTs 150* and really brought on the low-end kick!
I'd put an ATS 3-piece exhaust manifold on it as well. The stockers like to shrink. Lowered the peak EGTs by 50* and lowered the peak boost by 5psi. Anything to remove a restriction on the air going in, or coming out will help. I prefer to do airflow improvements, before adding fuel.
