ATT: P PUMP GURUS OR "KNOWLEDGEABLE PERSONS"
Re: ATT: P PUMP GURUS OR "KNOWLEDGEABLE PERSONS"
Postby bmoeller » Sat Apr 27, 2013 4:37 pm
ellis93 wrote:,didn't really notice a difference in the truck other than a little lowend smoke.....I'm talking a little puff :lol: that truck was such a turd on takeoff it had me pushing and pulling on the steering wheel....
Did you slide the AFC housing forward as well as the plate? If the AFC housing is back too far, you can actually LOSE power, even if the plate is slid full forward, and/or ground.
Don't waste the money on delivery valves, unless pulling out a set of 131s. Then, I'd only get the 181s. The 191s just mainly add a lot of smoke and higher EGTs, and no power.
A 97 Ram auto p-pump is 14* timing stock. Put mine to 16.25*. Dropped EGTs 150* and really brought on the low-end kick! :D A bit more smoke, but not bad. MUCH improved throttle response.
I'd put an ATS 3-piece exhaust manifold on it as well. The stockers like to shrink. Lowered the peak EGTs by 50* and lowered the peak boost by 5psi. Anything to remove a restriction on the air going in, or coming out will help. I prefer to do airflow improvements, before adding fuel.
SOLD- '99 3500, SO CTD, 5spd
bmoeller
Postby PToombs » Sat Apr 27, 2013 4:46 pm
Bryan, did yours drone at 16.25*? Did it have a muffler on it?
Postby ellis93 » Sat Apr 27, 2013 8:13 pm
Bryan,I can't remember. It was a while ago and I've slept since then several times :lol:
Postby ellis93 » Mon Apr 29, 2013 8:02 am
I think I know why this thing was a turd now. :D
The damn strainer in the tank was packed full of trash......I found that trying to scavenge fuel out of the tank, only flowed after I blew shop air thru the supply line.
Postby RCCUMMINS89 » Mon Apr 29, 2013 10:36 am
IMO
16 degrees timing, number 10 fuel plate, one turn on gov springs (turboram) and call it a day.
Put an s300g on that thing and it'll blow the doors off your 93......
Postby ellis93 » Mon Apr 29, 2013 12:28 pm
So would a 4.3s10 :lol:
That's about the only thing my 93 can't do 100%,only kinda @$$ it hauls is the flesh kind :lol: .
If I can make this thing run with/better than a lightning,I'll be happy as a puppy with two peters....not the toombs kind :lol:
There's some punk rich (da da's money) kid that I'm wanting to spank 8) .
Eric I might just swap turbos around with the dodge for the time being,I am not dropping a 1k plus turbo on a questionable motor
Postby RCCUMMINS89 » Mon Apr 29, 2013 12:37 pm
I hear ya there.
