Cummins/82 C10
Re: Cummins/82 C10
Postby ellis93 » Thu Jun 26, 2014 3:25 pm
The dang gasket pushed back into place :shock: with nothing more than my fingers. Cover bolts are tight,can't turn them. Guess somehow my cover "relaxed"?!?!? Whatever :lol:
I dried it all up with some brake clean and smeared some ultra grey under it. I'm gonna let it heal up and wait on a few parts that I'm going to buy. When they come in,it comes off and I'll fix this.....permanently!
Re: Cummins/82 C10
Postby Tacoclaw » Thu Jun 26, 2014 3:37 pm
Weld it to the block. 8)
Re: Cummins/82 C10
Postby dazedandconfused » Thu Jun 26, 2014 3:45 pm
Billet tappet cover!
Re: Cummins/82 C10
Postby ellis93 » Thu Jun 26, 2014 3:49 pm
Tacoclaw wrote:Weld it to the block. 8)
With some jb :lol:
Re: Cummins/82 C10
Postby ellis93 » Thu Jun 26, 2014 3:51 pm
dazedandconfused wrote:Billet tappet cover!
Nope :lol: if you could see it in this truck....sure, but you can't see anything. I'll just bend the lower and end flanges some and it'll be a done deal
Re: Cummins/82 C10
Postby PToombs » Thu Jun 26, 2014 6:28 pm
You were spoda clean it and glue it BEFORE you pushed it back into place! What kinda hillbilly parts swapper are you? :roll:
Re: Cummins/82 C10
Postby ellis93 » Thu Jun 26, 2014 6:47 pm
PToombs wrote:You were spoda clean it and glue it BEFORE you pushed it back into place! What kinda hillbilly parts swapper are you? :roll:
The kind that wanted to go home and wash he's a$$ ;)
It working, nice and dry when I made it to the house :)
Re: Cummins/82 C10
Postby DodgeFreak » Thu Jun 26, 2014 7:22 pm
lol I thought I was the only one that gambled by doing things like that lol..
Re: Cummins/82 C10
Postby ellis93 » Thu Jun 26, 2014 7:37 pm
:) I know my creations,limitations and "rigs". This will do for a few weeks,till I have time to fix it right.
Re: Cummins/82 C10
Postby PToombs » Fri Jun 27, 2014 5:43 pm
Crap! I forgot to check on that stuff for you! I'll pull the list now so I don't forget and have it for Monday.
Re: Cummins/82 C10
Postby ellis93 » Fri Jun 27, 2014 5:57 pm
No hurry mr Pete ;)
It's still dry
Re: Cummins/82 C10
Postby ellis93 » Sun Jul 20, 2014 6:30 pm
Oil leak again...... :roll: ......this time it's the trans cooler lines. Those dang metal lines that snake here and there,up down and around everything. That junk is gone,should've done it while I was piece milling the truck together :?
On another note,I've a pump coming for the dodge,so it's time to put some fuel to this chevy and make it respectable 8)
Re: Cummins/82 C10
Postby DMan1198 » Wed Jul 23, 2014 7:01 am
Do you know what's being done with the new one (delivery valves, holders, gsk, barrel and plungers, cc output, etc)?????????????
Re: Cummins/82 C10
Postby ellis93 » Wed Jul 23, 2014 10:12 am
It's a stock pump,used. It was said to be turned up but that's getting backed off. Basically with the exception of the injectors and turbo,all the fueling will be set to tow with as little smoke as possible. If that goal takes me back to stock fueling from the pump,then so be it. It's time for the old man to be put back to strictly business.
Re: Cummins/82 C10
Postby DodgeFreak » Wed Jul 23, 2014 12:30 pm
hows about this one for your chevy??
