look at the crew cab that followed me home
Postby MUDDY » Tue Sep 09, 2008 9:34 pm
:D
93/85 drw crewcab
getrag and 3.55s and gear vendor.
done right with complete wiring harness and everything from the 93 switched over. dash and all. the rear end from 93. quite a work of art.
new paint, int perfect. seats like new.
gooseneck and 5th wheel hitchs. guages put in when conversion took place. le package and all the goodies work perfect, cold air.
this truck had a virgin pump till a couple weeks ago and is mildly upgraded to 618 rwtq
a rare find. went right up to the factory and picked it up :grin:
97 D-3500 flatbed dually 385/837
93 D-350 dually
90 W-250
FOR IDAHO EVENTS WATCH
http://www.idahoturbodiesels.com
MUDDY
Postby RumbleFish » Wed Sep 10, 2008 5:24 am
wow, gorgeous truck. im jelous for sure. you picked it up at the factory? nice find!
Postby MUDDY » Wed Sep 10, 2008 7:29 am
yep, factory, as in hbowers shop :)
took several months of work for this truck to come to life in this configuration. he wanted to do it right.
harold wanted to do a cummins conversion project. completed this one, took it to may madness and entered it into the show and shine where it took 2nd place. it is also in the newest tdr issue #61.
this summer he let me take it off his hands as he knew i wanted it bad. it is an awesome ride and gets admiring looks wherever it goes.
i'm tickled that it is now mine :D
93 D-350 dually
90 W-250
MUDDY
Postby PToombs » Wed Sep 10, 2008 4:27 pm
Really nice truck. Good job Muddy! ;)
Postby PapeCAT » Wed Sep 17, 2008 8:38 pm
you need some coil spring spacers up front... other than that I love it... I am going to tackle one of these projects soon.
PapeCAT
Postby MUDDY » Thu Sep 18, 2008 6:50 pm
thanks guys :grin:
im tickled with that crewcab.
yep, i wish i had a couple more inches up front
93 D-350 dually
90 W-250
MUDDY
Postby Richie O » Thu Sep 18, 2008 7:59 pm
MUDDY wrote:thanks guys :grin:
PETE, leave that one alone. :lol:
Postby MUDDY » Thu Sep 18, 2008 9:26 pm
lmao :lol:
figgers i wld get caught using a poor choice of words :oops:
93 D-350 dually
90 W-250
MUDDY
Postby PToombs » Fri Sep 19, 2008 5:01 pm
Man, I guess I better stop back here later in the evening! ;)
:jumpsmile:
Postby NoFrills » Fri Sep 26, 2008 6:15 pm
do you know what frame that was used for the conversion I am getting ready to do the same thing but the crew cab frame is shorter then my cummins and can't make up my mind to strech the tall one or just use the shorter crew cab frame
NoFrills
Postby MUDDY » Fri Sep 26, 2008 9:10 pm
it has the 85 crewcab dually LWB D-350 frame. i have it and the 93 D-350 donor clubcab dually here and tommorrow i'll measure the height to compare
93 D-350 dually
90 W-250
MUDDY
Postby MUDDY » Sun Sep 28, 2008 9:59 pm
i grabbed the tape measure and whipped it out. i have 8 inches..........
i mean,,,,,,,,,,,,,,,,,,,, the 93 clubcab d350 dually has an 8 inch tall frame as does the 85 D350 crewcab dually frame. both 2wd
my 4wd W350 4wd srw 91 gasser had 6 in frame. the w350 srw cummins in 91 had the 8 inch. w 250 had the 6 inch. 91.5 if my memory is wrong both w and d 250s also had 8 inch with the mighty cummins.
your swb crew must be 6 in tall cuz of it a swb or srw and a 250
93 D-350 dually
90 W-250
MUDDY
Postby MUDDY » Sun Oct 12, 2008 1:00 pm
here is a buncha pics
93
93 t-gate before rhinolined
93 camptrip
93crewcab camp
93 crew at meet
93 crew at meet
Image[/QUOTE]
93 D-350 dually
90 W-250
MUDDY
Postby MUDDY » Sun Oct 12, 2008 1:02 pm
Crewcab ITD dinner meet
Here is the rear seat. The spot ya see is some spray foam which can be removed with a brush. The headliner is double walled steel. There is air space tween the 2 layers. For sound deadening and insulation Harold drilled 2 pin holes, one on each side and filled the space with spray foam from aerosol cans. Helps w/ sound deadening and temp insulation. I like this headliner much better than the cloth headliner which can show it’s age over time and sag.
Here is the overhead shelf console and the gauges are up top. The autometer pyro, boost, and trans temp. a 3 way switch lets the temp guage monitor trans, gearvendor, and rear end temp. this pic it is hard to see but visibility is great from the drivers seat. The shelf up top is handy too. Made of metal.
Ok, a better pic of the gauges
Here is the mighty Cummins. This inj pump was a virgin it’s whole life till a few weeks ago. 618 rwtq with mild mods including 3k gsk.
Here is a pic of the turbo. It is modded to a wh1c12. 12cm WG of a 2nd gen lets a 2nd gen downpipe be used. It goes to 4 inch exhaust thru a hi-flow muff to the tailpipe.
Take note of the ats exhaust manifold. New, just installed late may.
Image[/QUOTE]
93 D-350 dually
90 W-250
MUDDY
Postby MUDDY » Sun Oct 12, 2008 1:05 pm
Here is a pic of the crewcab at an ITD meet. You’ll also see a pic of this rig in the latest TDR magazine.
I haven’t put too many miles on this rig as I haven’t had it too long but mpg is awesome @ 20 to 24mpg range.
This is the switch for the gearvendors auxiliary transmission.
Here is a good pic of the ats
Dash. Apparently it has had a cover on it. I keep it covered now and in a shed and I believe this truck was garaged. The top panels were from the crewcab and the instrument section from the cummins donor. The dash is perfect as you can see.
Right side dash
Truck on a camp trip.
this CREWCAB has been doing a good job for us and fun to drive.
More pics to be posted[/QUOTE]
93 D-350 dually
90 W-250
MUDDY
