looking for injectors
Postby dodge09 » Wed Sep 30, 2009 11:31 pm
i was wondering what would be a set of injectors to buy for my 92 W350 5speed. say i have a south bend clutch my fuel pump turned up as far as she will go befor runnaway. 3200 gov spring. custom ground fuel pin and cold air intake. so i think all i lack is injectors and timming. well im looking for 40 or so HP gain but at a good price. i was wondering about POD's. if they would get me the gain i want. well if any one know please reply.
1992 dodge W350 4X4 5spd 5in stack, pump turnd all the way up ,custom fuel pin, smoke screw truned all the way in, star wheel truned all the way, 3200 gov spring, 18cm2 turbo. 30+psi of boost. boost and pyro gauges. K&N air filter with custom intake.
dodge09
smoke screw?
Postby peobryant » Thu Oct 01, 2009 1:22 am
POD's will probably get you the gain you want, but they are very dirty and inefficient injectors, so you will also gain a lot of heat and smoke, and lose some of your mileage. If you're not concerned with that, then POD's would probably be okay, and they are the cheapest injector I know of, but there are certainly better options out there.
If you don't care about smoke or mileage, then you could also consider a set of 6X.016's. I know Richie has a set, and likes them, but says they haze a lot, (he is running stock timing I believe) and I don't believe he gets very good mileage with them either. PureDieselPower has a set of them for around $500 I believe, which is not much more expensive than POD's.
On Edit: I looked on their website, and couldn't find the 6X.016's anymore, but I did find some others that might interest you, for a pretty good price. They have EDM'd 5X.014's (435's, advertised as a 120hp gain) for $479, and they also have DDP injectors, which they say are brand new, so they require no core, from $474, to $712. Keep in mind I have never used a set of PureDieselPower injectors, so I'm not sure of their quality, but their prices are hard to beat.
Postby diesel freak01 » Thu Oct 01, 2009 4:36 am
http://www.pensacoladiesel.com/index.ph ... ory_id=196
try there they have a couple sets and appear to be pretty affordable i dont know how reliable they are but i plan on trying them when i get around to it.
1993 d350 ctd drw 2wd auto
diesel freak01
Postby 93_Fummins » Thu Oct 01, 2009 6:43 am
The link for what peobryant was talking about. They are reconditioned cores...just to make note.
PureDieselPower 1st Gen 120hp Injectors
93_Fummins
