by peobryant » Thu Oct 01, 2009 1:22 am
POD's will probably get you the gain you want, but they are very dirty and inefficient injectors, so you will also gain a lot of heat and smoke, and lose some of your mileage. If you're not concerned with that, then POD's would probably be okay, and they are the cheapest injector I know of, but there are certainly better options out there.
If you don't care about smoke or mileage, then you could also consider a set of 6X.016's. I know Richie has a set, and likes them, but says they haze a lot, (he is running stock timing I believe) and I don't believe he gets very good mileage with them either. PureDieselPower has a set of them for around $500 I believe, which is not much more expensive than POD's.
On Edit: I looked on their website, and couldn't find the 6X.016's anymore, but I did find some others that might interest you, for a pretty good price. They have EDM'd 5X.014's (435's, advertised as a 120hp gain) for $479, and they also have DDP injectors, which they say are brand new, so they require no core, from $474, to $712. Keep in mind I have never used a set of PureDieselPower injectors, so I'm not sure of their quality, but their prices are hard to beat.
