My new fuel system
I just wanted to be sure
Postby ZSkibo » Thu Oct 08, 2009 4:35 pm
I had a good foundation for ANYTHING I might do later you know? I think I'm there...on to other projects.
92 W250 Pump bombed, AFC out, 366 spring, 18* timing, KSB hotwired, HX35 12cm non wg, New Era 6x18's, BHAF, 60 lb in/ex springs, 4" PAC Brake, onboard air, Nathan P3 horns
ZSkibo
Postby ahale2772 » Thu Oct 08, 2009 4:42 pm
lord knows we all have nothing to do, i have a rebody to do on my truck a z28 that needs a transplant, a mini cooper that needs a rollcage and a Deere that needs a cluch, thats why im hoping to do this once and not come back to it, thanks for all your help
Postby ahale2772 » Sun Oct 11, 2009 11:25 am
just did mine yesterday it came out good not a major upgrade but i can feel it pulls stronger i think my original was on its way out ill try to post a pic
Upgrade
Postby ZSkibo » Tue Oct 13, 2009 2:12 pm
No it's not a major upgrade but in a way it is. You have a solid foundation for power building AND you have the security of adequate cooling and lubrication to your VE now. Makes me feel better knowing that anyway.
ZSkibo
Postby ahale2772 » Tue Oct 13, 2009 3:43 pm
agreed its always good to do it the right way
Postby ahale2772 » Sun Oct 18, 2009 6:18 pm
so I permanantly installed a fuel pressure gauge in my truck this weekend and driving down the road the pressure going to the pump varies from 12 at idle to 20 regualr driving and spikes to almost 26 when i really put the hammer down and let off real quick never goes above 20 UNTILL I let off the pedal, like the pump cuts off fueling and the case pressure spikes ....maybe..??... i rigged the gauge with a 1/8 pipe thread fitting going to 1/8th inch air tubing all the way to the gauge ...i even blead the line up to the gauge ZSkibo Have u put a gauge on your system? i would think my pressures would be more steady with 30 psi coming from the truck and 15 coming from the regulator....any ideas?
Postby Ace » Mon Oct 19, 2009 7:29 am
Piston pump output goes up with engine rpm. Pressure at the output may vary with load throughout the rpm range, depending on supply restriction which you obviously have. You are probably going to blow the VE front seal after you let off at high rpm one of these days.
Postby ahale2772 » Mon Oct 19, 2009 7:37 am
supply restriction? i was thinking that the regulator would suck up all the highs that the piston pump puts out i dont see why im getting a 25psi spike out of the outlet of the regulator when i have it set at 15 psi at idle im thinking i should mount my gauge closer to the pump after the filter the spike only happens for a split second im starting to wonder if the pressure is isolated between the regulator and the filter (currently my gauge is located right on the regulator) but im kind of at a loss, Ace I agree that im gona blow the seal out if i dont get it in check...anybody think that if i put the gauge closer to the pump ill get a different reading ?
