head stud?
head stud?
Postby ditchman24 » Tue Sep 15, 2009 7:54 pm
Dose anyone have a part # for head studs that will work on a 91.5? Are they the same as a 94-98? I've called Arp and they can't tell me if they will work. What do I need? It's a stupid question, but I can't seem to get a good awnser out of anyone. Thanks for any input. Woody
"If it don't fit force it, if it brakes it needed replaced anyways"
ditchman24
Postby cummins king » Tue Sep 15, 2009 7:57 pm
yes the 12v studs from a 94 will be fine.
joel
93 4X4 auto
cummins king
Postby ditchman24 » Tue Sep 15, 2009 8:07 pm
thanks, can't seem to find a vendor that can give me a good awnser. ARP gave the contents, part #, and the length of each stud but could not give me a part # or a yes/no on the 94-98. I've been told but do not want to spend the money without being sure.
ditchman24
Postby soggy » Tue Sep 15, 2009 8:12 pm
12v ARP head studs are all the same, you will need to get the rocker pedestals machined also.
92 W250 VE Powered
13.31@ 98.92
1993 D350 Tow Rig
soggy
Postby BC847 » Tue Sep 15, 2009 8:42 pm
soggy wrote:You will need to get the rocker pedestals machined also.
Not with the A1 kit from Haisley Machine. ;)
Postby cummins king » Tue Sep 15, 2009 9:00 pm
ya thats right, thats what i have.
93 4X4 auto
cummins king
Postby fergavs » Wed Sep 16, 2009 10:29 pm
I have a set of ARP 12V head studs (only state 94-98 on box) and all I had to do was machine/grind the valve covers slightly to make the cover clear the stud. No machining of the rocker pedestals needed. Ill be putting a second set on my 4x4.
fergavs
Postby ditchman24 » Tue Oct 20, 2009 8:06 pm
thanks for the info guys, sorry about the delay.
ditchman24
Users browsing this forum: No registered users and 69 guests
