he351ve oil line help
Postby Deathrod » Fri Sep 10, 2010 3:38 pm
First off, Hi, I'm new to the board.....anyways i'm shoe horning a 91 non i/c motor into a 30' model A and I hung a he351ve off the side. The stock oil line fitting is much larger then the new turbo's opening....is there a reducer i can use? if so what size...or do i just need a whole new line. I cant seem to find on any posts on what size oil line the ve takes...help!!!
Deathrod
Re: he351ve oil line help
Postby lectro_static » Sat Sep 11, 2010 4:49 pm
My '93 used the stock line, just cant remember if it was stock for the truck or the turbo, truck I think tho. Are the lines for the i/c and non i/c turbos different? You can contact Thomas at M&H INC and he can help you with the oil line, they are great to deal with.
weeping head gasket
4" straight pipe
M&H M3 fuel pin
M&H Dynamic Timing Advance
366 spring
Auto Meter EGT and Boost
lectro_static
Postby Richie O » Sat Sep 11, 2010 6:52 pm
The non intercooled baby H1C turbo does not have the adapter he needs that will screw into the newer turbo. The later H1C's that came on the cooled trucks did. I ran into the same problem when I put a S300 on my 89. I had the ciummins shop order it as I could not find a used one at the time.
Postby Deathrod » Mon Sep 13, 2010 3:09 am
I dug up the baby HC1 and it actually had the adapter....with the thick black factory paint on it i thought it was part of the turbo. Thanks for the help...just need to get the car done so i can get it running
Deathrod
Postby gear jammer 91" » Sun Sep 19, 2010 9:36 am
Make sure to post up some pic's, it sounds like a cool ride.
01 LB7
gear jammer 91"
