SDX 5x.020
SDX 5x.020
Postby mike8061 » Sat Sep 24, 2011 4:28 pm
Cant seem to find any info on the .020 on here. Any one try them? Thinking of trying a set and a new turbo. Any thoughts?
92/93 W250 Ext. Cab. LP lift pump, 3200 spring, fuel screw maxed, pin almost ground through, 6" lift, flat bed, 35x12.5, big bumper
93 ext cab parted
92 reg cab parted
1967 C50 swapping in spare 5.9 auto and 205. 8.10 low in rearend. should pull somthin
mike8061
Re: SDX 5x.020
Postby dazedandconfused » Sat Sep 24, 2011 5:00 pm
What's your setup and what are you doing with the truck? Fill in your sig and welcome.
Re: SDX 5x.020
Postby mike8061 » Sat Sep 24, 2011 5:53 pm
Used to be my DD, just got promoted to project truck. Supposed to be getting my buddies 95 when he upgrades so i'll be taking the NV4500, Dana 80, seats and possibly frame for mine. Have another project in mind for the Ppump.
3rd gen cooler and rad waiting to go in but want to upgrade turbo(s) at same time. Was looking at the SDX .018 or .20, when this ip goes i'm thinking 14mm. would only like to buy the torbo(s) and injectors once and then build the rest to suit.
Also is 450-500hp a resonable number with the 14mm? Will be putting a new clutch in with the 4500 install.
93 ext cab parted
92 reg cab parted
mike8061
Re: SDX 5x.020
Postby The_Head » Sat Sep 24, 2011 6:44 pm
My thought is that they are probably too big for most setups.
30% more orifice area than 6 x 16's.
The_Head
Re: SDX 5x.020
Postby Tsbourne09 » Sat Sep 24, 2011 9:08 pm
Wow thats weired. I was just looking at the sdx page and saw them amd came here for info and saw this lol. These are huge right! The 5x.018 are prob better injectors for a dd and they are still bigger than 6x.016 right?
Not On Yet: 60#VS
Tsbourne09
Re: SDX 5x.020
Postby Jklawinsky » Sat Sep 24, 2011 11:45 pm
I would think 6x16 injectors combined with a 14mm head would be plenty of fuel, probably excess to run your common twins.
1992 w250 sittin pretty with a 4" custom lift, 2nd gen cooler, 4.10 gears, rear disc, 47rh lock up trans, 1/8 timing bump, 366 spring, custom fuel pin, BHAF, dual exhaust with Aero turbine muffler. boost, egt, trans temp guages with original tach... More to come!
Jklawinsky
Re: SDX 5x.020
Postby Remps » Sun Sep 25, 2011 8:40 am
Don't go bigger than 5x18 if you want it streetable. I gotta drive mine really easy around town to not leave a black cloud. Not a problem if you're not in a hurry. Anything bigger than 6x18 and you'll probably lose power, the testing has been done already. And all of it is in "the good stuff" somewhere..
Re: SDX 5x.020
Postby mike8061 » Sun Sep 25, 2011 9:29 am
The truck hardly sees town and when it does i'm in no hurry. I read somwhere that KTA was making 480rwh with the 12mm and a single and that spool was near stock.
This would be the upper end of the power range i'm looking for right now. It seems the 5x.018's are more suited to that level and would still leave some fueling room should i get more air and a 14mm later?
93 ext cab parted
92 reg cab parted
mike8061
Re: SDX 5x.020
Postby mike8061 » Sun Sep 25, 2011 9:45 am
http://www.forcedinductions.com/productsborgwarner.htm
Anyone deal with these guys?
Considering s300-62 ETT with .83 A/R
with http://www.steedspeed.com/cummins_straight_turbo_flange
I could get it with the external waste gate for more options for future twins
This with 5x .018 and from reading i dont think the lowLP will keep up. Hate to put electric pump on my all mechanical truck. thinking of electric fans when i put in the 3rg gen cooler and rad too :(
93 ext cab parted
92 reg cab parted
mike8061
Re: SDX 5x.020
Postby dazedandconfused » Sun Sep 25, 2011 10:08 am
I plan to use forced inductions myself. I have friends that deal with them and have great things to say. I don't think your gonna get that 3rd gen cooler in without hacking it up and rewelding it to fit.
Re: SDX 5x.020
Postby mike8061 » Sun Sep 25, 2011 11:35 am
Read a few posts that claim its a bit of work but it will fit. Bit of work on the support and notch the top of the frame rails. its not much wider just twice as deep. because i want to put the rad in as well and both are thicker than stock im thinking the electric fans will help alot with clearance. Be nice in the winter for warmup as well not having a fan going. plus its said to take 15-25 HP to turn the stock one. Can you tell im trying to talk myself into putting somthing electric on my truck?
93 ext cab parted
92 reg cab parted
mike8061
Re: SDX 5x.020
Postby The_Head » Sun Sep 25, 2011 3:29 pm
Aw come on, it has electric stuff already. An electric fan is a good idea.
The_Head
Re: SDX 5x.020
Postby mike8061 » Sun Sep 25, 2011 4:08 pm
I guess i can still limp out of the bush with no fans. I'll just have to run a valve setup so if my electric fuel pump dies i can switch back to the mechanical.... I'm not sure im joking or not
So i think i found 2 guys mentioning they had 6x18s and were happy with them? these are only very slightly smaller than the 5x .020, so now i'm am again debating between the .018 or .020
As long as i can get around slowly without leaving clouds at every intersection when i'm in town i'd like to get the biggest possible to aviod upgrading the sticks
93 ext cab parted
92 reg cab parted
mike8061
Re: SDX 5x.020
Postby Richie O » Sun Sep 25, 2011 4:17 pm
Its not as easy as being easy on it. Big injectors haze all the time. Some are better then others. Anything bigger then 6x16's on a single turbo truck is overkill. Thats my opinion.
Re: SDX 5x.020
Postby Remps » Sun Sep 25, 2011 4:30 pm
Mike 8061, you should look into a HP piston pump with a pressure regulator if you want to stay mechanical. Should keep up with a 12 mm IP, and if it doesn't you could tee in a holley black with a check valve to the outlet of the piston pump. That way you'd always have a mechanical fuel supply. Richie, you must have more than 301 hp with the 62/71/14? Isn't that number with the gds h1c?
