think i got it figured out...
Postby DTanklage » Fri Jan 18, 2008 10:19 am
need one truck for towing and can have one for playin
the ve head is cracked
dont want inserts in the towing head
thinking about having that head all done up, inserts, oversize valves, double springs, o-rings, etc, and then putting it aside
pull the '97 head, o-ring it, do a quick valve job, and put it on the ve motor
put the ve motor with the build 4500 and splitter in the 2nd gen and use it for towing (with it set up like it is, 62/65-13, etc). what a tow rig that would be!
then put the done up head on the '97 motor (which has better pistons) (and the pump), put it in the first gen, put a built auto behind it, put the transfer case back in it, alter the wheel base to std cab short bed length and put a short bed on it. then go crazy with the fuel and turbo systems
what a toy that would be!
lots of work tho...
DTanklage
Postby GO OVRIT » Fri Jan 18, 2008 3:13 pm
You must daydream as bad as I do :D Sounds like a plan though.
GO OVRIT
Postby DTanklage » Fri Jan 18, 2008 4:07 pm
well, what else can i do?
i want to go pretty crazy with the p pump motor and i HAVE to be able to tow
kta says that even if i go a little crazy with that thing it wont last pullin 30k+ pounds
(josh at woodruffs said same thing brian)
i wanted to have the best of both worlds but it does not sound like that is possible
not with one truck anyways
hehe
but with 2 it is possible (now i just gotta rob a few banks)
josh ayers is the one with the auto trans, 1 ton short bed 1st gen idea
and being that that one is 4 wheel drive...
(might need that if i get over 600rwhp)
or 700
or 800
yes, i am obsessive compulsive
big time
don
ps - do my best thinkin in the shower and on the crapper
lol
DTanklage
Postby flashgordon » Fri Jan 18, 2008 6:55 pm
DTanklage wrote:well, what else can i do?
hehe
or 700
or 800
big time
don
ps - do my best thinkin in the shower and on the crapper :pottytrain:
lol
You mist one ...........Fixed it for yeah! :lol:
flashgordon
Postby DTanklage » Fri Jan 18, 2008 7:19 pm
why thank you
DTanklage
Postby PToombs » Sat Jan 19, 2008 1:13 pm
Well, that explains all the sh*tty ideas! :hs:
:jumpsmile:
Postby PToombs » Sat Jan 19, 2008 1:14 pm
Sorry Don, I did hold back for a whole day! ;)
Postby DTanklage » Sat Jan 19, 2008 2:13 pm
ha
ha
ha
DTanklage
