need one truck for towing and can have one for playin
the ve head is cracked
dont want inserts in the towing head
thinking about having that head all done up, inserts, oversize valves, double springs, o-rings, etc, and then putting it aside
pull the '97 head, o-ring it, do a quick valve job, and put it on the ve motor
put the ve motor with the build 4500 and splitter in the 2nd gen and use it for towing (with it set up like it is, 62/65-13, etc). what a tow rig that would be!
then put the done up head on the '97 motor (which has better pistons) (and the pump), put it in the first gen, put a built auto behind it, put the transfer case back in it, alter the wheel base to std cab short bed length and put a short bed on it. then go crazy with the fuel and turbo systems
what a toy that would be!
lots of work tho...
