New Era 370's in:
New Era 370's in:
Postby MikeThomas » Sat Jan 26, 2008 3:44 pm
Just to say, im not being critcal, just sharing my observations, Chuck Is a super guy to deal with by the way:
So I got my injectors (370's) from New Era in today. Im on the fence at the moment about the bang for the $. When I first got them I was a little concerned because: a. They were dirty enough to make my fingertips black, b. the bag they came in was dirty and had 295hp crossed out and 370hp written below it..., and c. the copper washers had been crushed already. I called Chuck with these concerns and he stated that they may have been a test batch that got pulled off the shelf and dyno'ed on an engine....a little relief there. All went in well. My idle rpm has dropped a lot, which I understand to be normal for a larger injector, but she is also much quieter. Im not sure how much more boost im building because I was pegging the 35psi gauge with the stockers. There is definitely more pull at the higher rpms... something I felt the stock setup always lacked, but I cant gauge if there is a whole lot more HP....Maybe Im expecting more than what is actually to be? Smoke is a little more prevalent but not too bad....and EGT's, well i still cant hit 1200....the pump is fairly maxed out too.
Questions:
Do stock injectors have 6 holes?
If you run NE 370's, whats your take on them?
Chuck, if you have any input, please chime in (And thanks by the way!)
Sorry for rambling....Mike ;) :D
1993 W250, 5SPD, ne370's, HTT STAGE IV/14wg, DennT Pin, BHAF, P-PUMP, PUMP TWEEKS, 4" EXHAUST, 366
MikeThomas
Postby PToombs » Sat Jan 26, 2008 5:45 pm
I have a set, with the same exhaust set up as yours. I like 'em! :2cool: I went right from stockers to these, with the stage IV upgrade at the same time. Big jump in power and seat of the pants feel. More smoke, more boost. I put down 366 on the dyno last fall, and my fuel screw is over a turn from runaway yet. I'll take care of that this winter. ;-)
Oh, and I can hit 1500* in 4th at about 3400 rpm. (roughly 93 mph).
Postby Begle1 » Sat Jan 26, 2008 7:38 pm
Cool, somebody else with 370's.
Hopefully you can back up Sheepie's dyno numbers and prove that he didn't just get a fluke set.
Postby PToombs » Sat Jan 26, 2008 7:44 pm
What's a Sheepie? ME? :shock: I was 1/2 way thru a sentence when I realized you meant me! :oops:
Postby DTanklage » Sat Jan 26, 2008 7:55 pm
why do bigger injectors decrease idle speed?
or why do you think they do
it works the opposite on my truck
when i put bigger inj in the idle speed increases (and it gets quiet)
don
DTanklage
Postby nooblet » Sun Jan 27, 2008 12:43 am
PToombs wrote:I have a set, with the same exhaust set up as yours. I like 'em! :2cool: I went right from stockers to these, with the stage IV upgrade at the same time. Big jump in power and seat of the pants feel. More smoke, more boost. I put down 366 on the dyno last fall, and my fuel screw is over a turn from runaway yet. I'll take care of that this winter. ;-)
This is off the subject at hand (sorry). What do you mean by stage IV upgrade? I see a lot of people talk about that and I have no earthly idea what you guys are talking about here. Excuse my ignorance lol! :shock:
Chris
nooblet
Postby Philip » Sun Jan 27, 2008 7:38 am
Its a HTT turbo upgrade. Bigger intake wheel and housing.
Postby PToombs » Sun Jan 27, 2008 10:00 am
A Stage III upgrade is a 8 blade 60mm compressor wheel and housing.
A Stage IV is a 6 blade, taller 60mm wheel, housing, and backing plate with a cut for the deeper wheel.
You can get a Stage IV from GDS, (Gillettes Diesel) for about $100 less, but you have to get your backing plate machined. I didn't want to mess around, so I spent the extra so I could swap it quick. ;-)
Postby DTanklage » Sun Jan 27, 2008 12:58 pm
how much money can you spend on a hx-35?
DTanklage
Postby PToombs » Sun Jan 27, 2008 2:05 pm
It's about the same for the HX upgrade as for the H1C.
Postby DTanklage » Sun Jan 27, 2008 7:49 pm
so what is that?
600 bucks?
how much do they (stock 35) bring used?
thanks
DTanklage
Postby cummins king » Sun Jan 27, 2008 9:34 pm
i can get them as cheap as 100 bucks no garenty if its go or not, a good one maby 3 4 hunderd for a good one
93 4X4 auto
cummins king
Postby DTanklage » Mon Jan 28, 2008 9:49 am
so all said and done its about a grand for a good one thats been done up...
right?
how much do used s300's go for?
DTanklage
Postby roxxx » Mon Jan 28, 2008 11:00 am
really sittin on the fence between the 370'S and the 430's. cough i am even thinkin of the ddp 4's. does anyone have the 430's or the ddp 4's in as a daily driver ? spring is coming lol getting ready to start modding
1992 4x4 Reg cab LE 5 speed
4 Inch lift
Bilsteins shocks 5125
VE moderately molested
Dana 80
ultra wheel rims Type 164
ASA pipe BHAF 19037
Outerwears prefilter
A A nv4500
roxxx
Postby JQmile » Mon Jan 28, 2008 1:43 pm
I like the DDP4's...they seem to be a pretty efficient injector, no cranky morning start smoking, not too bad through the curve either unless the pump is maxed. Also heard you can send 'em back within 30 days if you feel they're too conservative and Dynomite will open 'em up :P Fuel mileage is still good too.
JQmile
