injectors?
injectors?
Postby Lee Majors » Sat Jun 28, 2008 7:25 am
Will my 215hp injectors out of my 9812v fit my 91.5 12v?
What is the limitations of the stock auto transmission on these beasts? mine is a dually with a flat bed.
I want to put the govenor spring in along with a HX35 & some injectors. Just enough to give me a little bit better excelleration.
1991.5 D350 dually flatbed stock
Lee Majors
Postby Philip » Sat Jun 28, 2008 7:51 am
The 2nd gen injectors have a different thread on the fuel line.
If you already have a HX35 go ahead and use it. If you don't step up to a better turbo. Go to a S300 or a Super HX40. Both require a 4' exhaust. Your wanting to throw some fuel at it the truck it needs a 4" exhaust anyway.
The stock auto has a weak converter. It will not take much for the converter to slip bad.
Postby CumminsPride » Sat Jun 28, 2008 9:05 am
The only thing you could use is the nozzles from your other injectors. Although I doubt that the 215's would be any kind of improvement considdering they are probably smaller. As for acceleration, the governor spring and a maxed fuel screw accompanied with a ground pin makes for a good runner even on your stock injectors. If I were buying "off the shelf" injectors, I would seriously look at New Era's 370's and a 62/65/14 or similar turbo.
06 3500 AT Mega Cab SRW 4X4
CumminsPride
Postby skilletky » Sun Jun 29, 2008 1:13 pm
i would do what CP say!! i put some new era 370's, a gov spring, fuel screw all the way in, and a htt 71, and it turned out way better than i hoped for. even with the stock trans about to come apart, and it not wanting to hit over drive at wide open throttle, it ran a 15.4 in the 1/4.
skilletky
