1991cummins wrote:i agree with pulltillbroke, get the right one too... too little converter means it hurts the wallet twice, too much converter only once
lol...
'91 Cummins wrote:Also, for $105 you can get the best fuel pin available for our trucks shipped to your door. If you're interested go on the DTR and PM member DennyT and ask about his fuel pin.
PToombs wrote:'91 Cummins wrote:Also, for $105 you can get the best fuel pin available for our trucks shipped to your door. If you're interested go on the DTR and PM member DennyT and ask about his fuel pin.
Save your money here too. Grind your own. There are a bunch of threads on this on several sites.
'91 Cummins wrote:Plus, if for some reason you want to go back to stock, you can just put the stock pin back in, unless you grind it of course...
PToombs wrote:'91 Cummins wrote:Plus, if for some reason you want to go back to stock, you can just put the stock pin back in, unless you grind it of course...
Just take it out, turn it around, and put it back in. Done deal, stock pin.
PToombs wrote:You only grind 1 side, actually. The other side should still have the stock shape.
You can do what you want, I just don't see the need to spend $100 for something I can do myself. I've had good luck with mine, and many others have home ground pins too.
To each his own!
