HX35 on an 89
HX35 on an 89
Postby Redneckintraining » Fri Jan 09, 2009 11:18 am
So I bought an HX35.It should be here sometime soon.I understand that I need to mod the exhaust and the intake for it to fit.As well as clock the compressor housing. Does anyone have any pics of how they modifified the 89 intake airhorn to fit?Also how do I clock the compressor?I know that "clocking" is just rotating the compressor housing but how is it done?Other than the above any thing else to look out for line oil lines?
thanks in advance.
Redneckintraining
Postby SChandler » Fri Jan 09, 2009 12:10 pm
There is a narrow v-band clamp on the compressor housing that you will loosen to rotate the outlet to match. I think a silicone reducer hump hose could be used. The outlet on the HX35 should be 2.5" while the intake pipe on to the engine is 2" diameter. As far as I know, the oil lines should bolt up OK. I haven't done the swap, so I'm not 100% on the oil lines.
SChandler
Postby Free89W350 » Fri Jan 09, 2009 12:21 pm
Yes you will need a reducer to go from your crossover to the HX35. You will also need to cut approx 2" off of the crossover and grind the lip off of the compressor housing for the rubber reducer to fit over. You might be able to get the elbow that would go from the compressor to the innercooler piping to work for you but I am unsure because I just ground down the housing.
05 GMC Sierra Z71 6.5" lift and 35's
95 VW Golf VR6 5 spd
Gone but not forgoton :(
89 W350, Auto, Non Intercooled, 3.07 rears, Star wheel full up, full power as far as possible, smoke screw just a plug, fuel pin ground & washer shaved .90, 366 spring. Jardine 4" exhaust.
Free89W350
Postby RumbleFish » Fri Jan 09, 2009 1:01 pm
you could also make a 2.5" cross over. i have one around here somewhere that i never used. i havent seen it in a long time though...
Postby PToombs » Fri Jan 09, 2009 5:27 pm
RumbleFish wrote:you could also make a 2.5" cross over. i have one around here somewhere that i never used. i havent seen it in a long time though...
I think the neighbor stole it and was using it for a weed pipe. ;)
Postby Richie O » Fri Jan 09, 2009 6:10 pm
Can't he just take off his exhaust housing and swap it to the hx35. That if he can live with the 18.5 housing :D No exhaust work at least.
Postby boostedve » Fri Jan 09, 2009 6:44 pm
Hey Pete are you that neighbor :thumleft:
FOR SALE 1991 dodge d350 hx40 2nd gen intercooler, few pump mods, 366 spring, no afc, timing bump,pistion lift pump, 5" down pipe, bhaf, old smokey fuel pin, boost, pyro, tach gauges 14.10 @96mph 310hp, pm for pics and info..
boostedve
Postby RumbleFish » Fri Jan 09, 2009 8:39 pm
boostedve wrote:Hey Pete are you that neighbor
no way. ive had questionable neighbors around here, but nobody that bad!
PToombs wrote:I think the neighbor stole it and was using it for a weed pipe. ;)
that really wouldnt surprise me. at least the crackwhore that lived next to me when my 91 got hit in my driveway by her brother isnt there anymore. that still pisses me off...
about the only one i have to worry about is the guy that had all the cops over. he doesnt drive though. and i havent seen him since he overdosed on vicoden (that was when the cops came).
Postby 1991cummins » Fri Jan 09, 2009 9:19 pm
no, there is not a v-band holding on the compressor housing like on the h1c, there is a giant c-clip thing that you need to squeeze with a big pair of vice grips, it takes some nuts... also the intake of the turbo is an inch bigger than your current, the exhaust, unless you switched the housing, will have to be 100% modified, and welded together... the oil lines i have seen different, but i have seen the same :? so i dont know what to tell you... also, live a little lip on the end of the compressor to allow for the boot not to slip off as easily... i have done two swaps, and this is my experience...
:) it shouldnt be too bad... it should be pretty simple, just try to think ahead when your doing it ;)
1991cummins
Postby Redneckintraining » Sat Jan 10, 2009 1:08 am
I imagine my exhaust housing is chewed up,the compressor is. Only replacing the turbo cause its blown...
I suppose I can see how bad it is though..
Redneckintraining
Postby PToombs » Sat Jan 10, 2009 8:34 am
The HX-35 I had was a clip, it also had a small roll pin to hold the housing in one place. Pull the clip, remove the compressor housing, and clean the edges. Then you can see if it has a pin, and it will slide better when it's clean.
Postby Free89W350 » Sun Jan 11, 2009 8:20 am
As far as the exhaust being 100% fabbed up NOT TRUE. It will have to be moved back 1" to 2" and the bracket at the trans moved or scrapped but it is not that big of a deal. I kept the 18cm on my auto truck and really like it but am going to be putting on the 12cm housing soon.
Free89W350
Postby CaptainChrysler » Sun Jan 11, 2009 3:02 pm
I put a 12cm on my '93 and was able to move the stock exhaust back and keep the bellhousing mount.
As for the oil line, you will need the fitting for the inlet of the HX35. The '89's I have seen don't use one, the turbo is machined for the double flare fitting. The newer ones use a fitting to adapt from SAE o-ring to double flare. It might be robbed from the HX.
1993 W-350 EXT CAB SRW
GETRAG, DC-1'S, 285'S
370'S, HX40, 5" EXHAUST, BHAF
1989 W-350 SRW
GETRAG/NV273
P-PUMPED, 2.6" S400
WATER-2-AIR IC, SBC DD
CaptainChrysler
Postby Redneckintraining » Sun Jan 11, 2009 7:55 pm
the double flare fitting?
What can I do to rectify that?Right now my truck is down because of its blown turbo. So I kinda need to get it going as fast as possible.
Redneckintraining
Postby CaptainChrysler » Sun Jan 11, 2009 8:40 pm
Where are you getting the turbo? New? Used?
1989 W-350 SRW
GETRAG/NV273
P-PUMPED, 2.6" S400
CaptainChrysler
